Is degreaser safe?
Luke
Is decreaser safe on tires and wheels? Does it clean well?
Amazing roll off is a degreaser that is safe on wheels and tires.
What about like the Walmart decreasers.
What about like the Walmart decreasers?
Just use all water based stuff.
there are alot of diffrent degreasesers, trust me. Most are safe, however you do rin into a few problems with some. The trick is to look for one that says water based, or ph nuetral. This dosent make them safe but it does help.
Try to find a good Citrus Degreaser OTC, I happened to run by Big Lot's one day and grabbed a bottle, should have grabbed more, it was made by Simonize and suprisingly it's pretty damn good and being citrus based isn't as strong as the real acidic ones. Otherwise get a good degreaser on here (AG), and some products like DP Exterior Cleaner will work just as well
