Is DP Poli-coat an AOI?
Goodloe3
I have read on here and some say it is, other say it just has bonding agents. Does it act like a real AOI in that it cleans the paint, removing old wax/sealants? Can it be layered? Will it remove glaze oils?
It is not. DP poli-coat is a sealant. Perhaps you may be thinking of poli-seal made by Optimum, which is indeed an AIO, and one of the best.
:iagree:
Goodloe3, what you may also be confusing is the cleaning ability of poli-coat. It's more on par of a chemical cleaner, like a non abrasive paint cleaner/ cleanser, rather than a correcting product like a micro abrasive polish. DP Poli-Coat contains a prepping agent that preps the paint as you apply it, eliminating the need for a dedicated paint cleaner before sealant application.
Thanks guys. So since it is a chemical cleaner, would it remove glazing oils?
Yes. Well to an extent it would.
Still best to try and avoid a glaze in the first place with most sealants. :buffing:
