Is Graphene the next big thing for coatings?
The Guz
This is going to be a long one so lets see who makes it to the end :)
As stated in the title of this thread, is Graphene the next evolution of coatings or is all hype?
We have all seen Graphene become the next buzzword in the world of ceramic coatings and all these youtubers praising how great it is as the next big thing while sort of writing off Silicon Dioxide coatings without any further test data. I attribute this to not having time and being sent various products to test out. So I am hoping to provide some feedback that is somewhat useful.
Before I move on I will be referring to Silicon Dioxide coatings as SiO2, quartz or ceramic. All are interchangeable.
At the time I am writing this, it is too soon to tell if Graphene will stick around as these products are in their infancy. Will it fade away in existence or will it survive the test of time like quartz based coatings.
We have a multitude of coatings along with different variations of chemical make up these days. These coatings are tried and true and they are going to stick around for awhile. Graphene has a lot of work ahead to dethrone SiO2.
Next we move onto pricing. Graphene is expensive and thus the product is expensive. At the same time these introductory products probably don’t contain too much Graphene. Again it is an expensive substance.
A known fact is that quartz coatings are prone to water spotting. Not everyone has experienced this issue and those that have get disappointed due to wanting that perfect product. The holy grail. This is where Graphene coatings are claiming anti-water spotting. This may be true but only time will tell if this solves that issue. At the same time the current Graphene coatings are sacrificing hardness. Although not something to really focus on. For example SPS claims 7H while other coatings are claiming 9H and some even 10H.
I originally wrote this review on the SPS Graphene Product sometime ago. Unfortunately I did not have it on long enough to really provide good information on.
Review - SPS Graphene Coating
I then added it as part of my coating test comparing it to other coatings.
2020 Ceramic Coating 1 Year Test
I decided it was time to polish my Grand Prix as the 21 month Cquartz UK 3.0 did it’s job. Such a great coating. I chose to go the SPS Graphene route to get more data and to see how well it would perform long term.
I have a friend of mine who whispered into my ear that IGL is planning to release a Graphene coating through their authorized installer network. This got the wheels turning and asking “what if I use IGL F4 Renew as a primer polish?”. Those of you familiar with the product will come out and say, Mike you are crazy since IGL F4 states it is not to be used a primer polish. This is true. This product would fall in line with something like CarPro Essence. I thought to myself as soon as IGL releases their Graphene coating they are going to come out and say yeah F4 can be used as a primer. I even contacted IGL through facebook asking them if it would work with another Graphene infused product. All they said was no with no real reason. I read the back of the label a few times and IGL states F4 is not to be used as a primer for their Eco Coat coatings. Their eco coat line is all quartz based. Well SPS is not quartz based. So why not use them together is my way of thinking.
This is the end result.
So I proceeded with my course of action. I did the normal chemical and mechanical decontamination. Followed that up with Meguiar’s M210 on a Rupes yellow pad using carious Rupes tools. This was more than enough to remove the 21 month Cquartz UK3.0. M210 is impressive on its own and the gloss it was leaving was great. I followed that up with a prep wipe using Meguiar’s M122 Surface Prep. Came back with IGL F4 Renew on a Rupes white pad. Let that set up for a couple minutes after wipe off and then followed up with Meguiar’s M122 to remove any remaining residue without removing the deposited Graphene. Finished it off with two layers of SPS Graphene coating.
The paint was in good shape. I gave myself a pat on the back for keeping the paint virtually swirl free for 21 months. I saw no defects under the Gyeon Prism Plus light on the silver paint. The swirls on the black pillars were minor.
Before on the left and after on the right after using M210 on a Rupes yellow polishing pad. I took advantage of the minor filling from IGL F4 later on.
The end result of all this work was a glossy and silky smooth finish.
The paint was much brighter under the sun after after polishing and a fresh new coating.
I am going to mention this. This is more of an experiment to see if these two Graphene based products play well together. Detailing in the end involves experimenting with products from time to time. This can sometimes result in a failed experiment or a successful one. I am not concerned with durability or longevity with this combination. We do still have the coating test where SPS is bonded to bare paint.
A few thoughts on the products I used.
Meguiar’s M210 is a very good polish. Easy wipe off and definitely less oils than M205. A little less cut but the finish from it is great.
For IGL F4 Renew, the first thing is swap out the cap. It is terrible. The product itself is thin and rushes out of the cap. IGL needs to get rid of these caps. As far usability it is pretty straightforward. The minor issue is that it can be a pain to remove if it is left to sit too long or if there is excess product say when turning off the polisher. The overall finish is very good and the surface is nice and slick.
SPS Graphene is nice to work with. It does not need long to sit once it can be wiped off. It does not rainbow like a typical coating. The overall finish it leaves behind is silky smooth and it gets even slicker the longer it cures. Think Gtechniq CSL/Exo combo or Gyeon Syncro, either Cquartz coating topped with Gliss, but on another level. It just feels different in a very good way.
Thanks for reading through and stay tuned for updates along the way. I will be maintaining it with the SPS Graphene spray detailer. I also applied SPS to one of my wheels on January 25, 2020 to see how it holds up over time. So far so good.
Application
Walk around
Great write up. I posted in another FB group about not liking the removal process. I retried it, and although I do not like the dry, wet, dry removal method, it was better the second time. It absolutely does help with water spotting. I have noticed a difference on my wife’s Hoonday. For some odd reason, since moving 5000 feet higher in altitude, I have noticed water spotting to be worse than I was used to in the Midwest. Since applying SPS Graphene, the water spots are virtually non existent, and remove easily. As an installer, it irks me a bit, that you can get the exact same product with a different label and not need to be authorized.
Graphene...for automotive paint Coatings?
Nope. It’s a whole bunch of “b%!+#<?@”!
[OOOPS...meant to say:
Nope. It’s a whole bunch of ”Buckyballs”!]
Interested in following along. Love to see new stuff like this but overall, I still enjoy the products I work currently and really haven't seen any downsides to them. Waterspots from hard water out of a garden hose can be an issue but in terms of a vehicle sitting out in the summer rain and having dirt dry on it, I've not had issue and black has been the color I'm doing most of and currently own. My Q50 currently resides in the driveway and Cquartz and Gliss v2 are still going strong on it with no concerns.
Following along though for sure.
Dunno if it's the Graphene or other things in the formulation but the Graphene coating I've had on my car since May 2019 has been one of the better coatings I've tried. Very vivid shine, great hydrophobics and self cleaning characteristics, slicker to the touch than most coatings. :shrug:
Thanks for the review Guz, great job. Don't get me wrong as you have the best looking 99 Pontiac on the planet, but I wish it was black for all of your testing.
Only wish they would make a coating that is hydrophilic be it graphene or not. BTW any problems with water spotting?
No problem with water spotting but I've never really had that issue, local climate maybe? It is Cleveland though where our river caught fire in the 70's and we still have smog testing in our counties so it's not like this is a 'pure' area
FWIW, I tried a coating last Winter that was noted/marketed as being hydrophilic as opposed to hydrophobic, documentation mentioned it would reduce water spotting but also reduce self-cleaning aspects as well. Documentation was correct...it's rather unexciting.
Graphite is ‘Hydrophobic’.
•Contrarily:
-According to the latest study published
in the journal ”Advanced Materials”...
Graphene, which is made from graphite,
is actually ‘hydrophilic’.
•Which, IMO, begs the question:
-Should a Coating exhibit the water-behavior
known as Hydrophobicity; then: can it truly
be a genuine Graphene Coating?
Thanks. Dave from Autopia hooked me up with the most recent version which does not require removal with a damp towel. I had no issues with removing it. It does take a little more effort if it sits too long. It does not take long for it to set up.
Thanks for posting feedback on water spotting. I have not had issues with water spotting on coatings so I can't comment on that part.
I understand what you mean about the art de shine stuff being readily available which takes away from SPS. I am not sure how close the formulas are to each other.
Every time I see you post in a topic of coatings it reminds me of this :laughing:
I am with you. I have not experienced water spotting with paint coatings.
Thanks but I don't wish that at all haha. For me it is either silver or white or anything in between. No black for me whether it looks good or not.
You can see how this black charger came out when I applied SPS to it.
2017 Dodge Charger Daytona 392
Didn't dallas paint correction come out with one? Ammo NYC has their reflex sheet coat.
Thanks for posting about your experience with a hydrophilic coating. Some of like that extreme hydrophobic behavior.
•Contrarily:
To bond, or not to bond, that is the question ...
You think that’s something?
Well get this:
Every time I see you post, regardless the
topic, it reminds me of the following:
‘For some reason, some people find you credible.
I don’t get it; but will definitely exploit it’. :laughing:
Nah just slightly less hydrophobic. It sounds like semantics but the difference is important imo. A with a hydrophilic product water would stick, like when you hand wash your glassware. Ideally the product would also also be oleophobic and repel oils. A product like this would be visually boring but the best thing to reduce wash induced marring. I think I'll just have to become a youtube chemist and make it myself :D
Well get this:
Lol I see you didn't take that well and it struck a nerve. I have two simple solutions for you Mr. Bob. Either don't participate in any threads that I start and/or block me and you will never see a post from me on the forum.
I am sure you are familiar with the term haters gonna hate. I found this and maybe I should be thanking you instead.
Why do haters hate?
Criticism is self-hate turned outward. Hate is often a sign of weakness, envy and fear. Haters hate on you because you’re doing what they cannot, will not or are too afraid to attempt.
Haters are a natural part of the growth of your business. When you’re new there will be critics, when you’re good there will be haters, and when you’re excellent they will turn into admirers. The question is: Are you willing to be attacked and criticized as a person to grow your brand?
There is one way to avoid having haters. Sit on the sidelines, do nothing, don’t set goals, be average and no one will judge or hate you.
Criticism and hate are the price you pay for taking your business to the big time. So don’t let the sound of your haters overwhelm you, you only give them power if you listen to what they say. Ignore the noise and use your haters as fuel for the fire. They’re hating you because you’re on to something and are doing big things. In a way they are one of the greatest forms of feedback you can get.
Ah thanks for the explanation. I don't follow the guy or his product line. I am sure you will gain many subscribers doing so :).
Also just because a product has a chemical doesn't mean it's doing the "work". Peek the thread from the new 3D coating that has SiO2 but isn't a "SiO2 coating"
https://www.autogeekonline.net/foru...-compound-finishing-polish-3.html#post1671222
Sub'd regardless, thank you for testing! At the end of the day we just want stuff that works!
Well said.
I saw graphene demonstrated on Forensic Detailing's channel about 4 months ago. I made a mental note to check it out this summer but still have not done so with everything that has been going on.
Are there many companies selling a graphene coating yet or just the SPS one?
What kind of pricing are we looking at per application?
Right now I use 2 coatings : McKee's 37 for my 2 year product and Gtechniq CLS for my 5 year one. McKee's cost almost nothing to use. About 5$ per car. CLS is about 80$ per car. I think the most expensive coatings on the market were from Optimum and Ceramic Pro, might be wrong. Opti-Coat Pro+ was in the 400$ range if I remember correctly. Never asked for pricing for Ceramic-Pro cause I have no interest in their products and company.
Any of you thinking about switching to graphene?
What graphene product can u get not being authorized?
nOjrx3ik4kzx6hie7fOjhHvfCBqUxNELfSv0pvL-1CizPDtfj7XwlrZpZ_RXd6m9Xy4naD9edOzsUh2XxvSpL_Qmlc7Y_YhSne7RwZsea3T8r2RqJkCbnpzqUYoV_3woLnIvKKLb7uAtxklXVdQgafC0ZBP1LzR3hSbhqPXNTRzj3zGKwy9lMJ5CP7S0-3C2xQ3vicEGpMynKz0SZIZe5UU8aT-xWOU5rXw5xeZv_OAa3YeQZaPgGsnxrKzxBkF6VoBy4yluS5u0FAo9YwtoAcaJPh4A8GEuwM_xb1RQw6kumTjMG8peZlLt22RBxHP9TfVUfT-2PgHljuCVY0E_yc5FPbjMR9orG60irQx6LtL25VM9pFDH30BL5sWUqCG7jQKF4VBtuHJ5_Nu5brOQtrLOnL2zoB9xl6MwQLKDquT7MzT5L5FA8AgaiIoH4BmGsBOiaNMkLbGRvwrqlJktTQQR0zSdSWU1WmmLSKvRo26ds_9vIIdLgjpW0UiyAHDm3Cgjus70PA-dnKjlS8Ov8t8iucF5nPNfBQLzWi34DFd0MJGobTuTp2wsnczVTQ-H37ju3xU8Qlpy4l7C3TBue7dmBwCgkfB9xa0sEO5rBasdBdlV8GMezjmEXJhYRHP-oTEy_WjkLmWlE8Sjh3gtlONHwtXKo8KNQm2mpyVcqBYoX43NJNQfJLRSY3tc=w1000-no-tmp.jpg
As always Mike, great review.
Got a little bit of humor going in this one plus some sheer honesty.
Actually Borophene is probably
the next big thing in Coatings.
