Is It Worth Upgrading From 7424XP TO GG6?
Which pads do you recommend? I normally use M105/M205. I use the M205 first then the M105 (unless the area needs major correcting).
I am just hoping that was a type-o on using 205 first then 105 cause 105 is the compound and should be used first then finish up with the 205 finishing polish.
To answer your question...Yes, it is worth it for several reasons. First the GG6 is considerably stronger than the PC. Second, the PC can now be downsized to smaller pads and backing plate for the hard to get areas. Big areas with the Griot's and smaller areas with the PC.
5 1/4" pads on the Griot's for best performance
