Is the Dewalt 443 ok?
AfireINSIDE
I know this is probly the wrong fourm, But in high school I worked as a new car prep guy. I bought a re-firb 443 from the tool guy one day for like $50.00 and have never touced it untill I got on here and decided that I wanted to start detailing. Now is this a good unit, I really dont have the cash right not to get a PC but will when this dies. Also any idea on its backing plate and where to get one? mine rotted off lol. Thanks
AS LONG AS YOUR SPINDLE IS 5/8 YOU CAN GET THE PLATE ETC HERE AT A.G.
http://www.autogeek.net/circular-polishers.html
http://search.store.yahoo.com/cgi-bin/nsearch?catalog=autogeek&.autodone=http%3A%2F%2Fwww.autogeek.net%2Fnsearch.html&query=RANDOM+ORBITOR+BACKING+PLATES&x=5&y=13
make sure it is a random orbital and not a circular, good to go !
yes it is a random orbital, the unit dosent have a spindle it has the dewalt 4 torx screw that hold the plate on, unlike the PC.
Should be a good unit from what I've read over on Autopia. I think this unit cannot use the usual backing plates, but the one it has is fine for the 6-7.5" pads. It actually has a little more power than the PC, so it may be better. I thought about getting one, but they were a fair amount more expensive than the PC.
DW443 is an excellent unit. You are stuck with the one backing plate but the more powerful motor and higher speed more than makes up for it. Our PC's are delegated to the 2 7/8 and 4 in backing plates. The 443 is the go to machine.
Good to see you here 3Dog,
I totally agree. It is more powerful so allows you to get a bit more without having to look for a rotary/and fewer passes. It is a DA polisher so its safe like the pc. It is also less prone to being bogged down like the pc since the stronger motor. But it does not have changable BP so you must stick with the 6" BP that it does have (most common one I think) and that meens you can get pads from AG as mentioned here.
thanks all, I am going to contact dewalt and get a new plate. The larger pads dont bother me thats what I used to use anyhow.
Hey all, I have the 443 too and love it! Is their a place that compares each speed setting to the PC unit? For eg. if someone says put your PC on speed 5 that would be what speed for my Dewalt?
I'D SAY YES........5 FOR 5000 OPM'S...if your 443 has a #5 speed......
Speed 5 on a PC would be about 4 on the DW. The should be a speed chart with the unit.
I too got a DW443 ROP!
Can you tell at how much pressure the pad stops rotating!?
I tried it with a 8" pad(for trial purposes) and it stops fairly quickly!
Any modifications to be done to increase speed?
OMG! I love your KB method!
It has worked really well for me on a rotary! :D
btw here's a thread I posted regarding the DW443 - http://www.autogeekonline.net/forum...-dewalt-dual-action-sander-polisher-help.html
Have you used this unit?
Does the backing plate rotate as freely as in a PC?
any tips/precautions etc.while using it?
Feed back please
btw I read your articles and posts on MOL and they were like super informative.
Thanks a lot!:dblthumb2:
Oh, cool. You're on the ball!
Just outfit the machine with thin pads that aren't super-cushiony. The backing plate motion will more accurately transfer through a thin, somewhat stiff pad. "Stiff" does't necessarily mean the pad will scour... the foam used to make the Meg's burgundy pad is a great example of what I mean.
"Oiling" stuff inside the machine isn't going to do much good, since the machine uses two stacked, high-quality SEALED bearings to support the free rotating shaft.
Backing plates spin easier if the bearings are looser. In other words, if you flick the backing plate by hand on two identical machines, but one spins less than the other using the same force, the one that rotated more by hand will rotate more under full throttle.
The DW443 features a smaller stroke than the G110v2, the newer Griot's machine, and the Porter Cable 7424XP. Therefore, it will not generate or cause the same amount of random rotation that these three machines will, all other things being equal (pressure, pad, product, paint, etc.)
Just use the machine wisely, and enjoy the results.
It's not always the biggest "gun" that wins the duel- a good "aim" is just as effective.
Get my drift? Technique makes a big difference.
Thanks.
Yes, I own two, and sold maybe a hundred of them and the earlier Black and Decker version (6121) combined.[/quote]
Not generally. The smaller 3/16" diameter stroke limits it compared to the 5/16" diameter stroke commonly used in the Meguiar's G-series and Porter Cable units.[/quote]
Any tips/precautions etc.while using it?
None more than in the previous post! :xyxthumbs:
To clarify my response to this:
Does it spin as freely?
Depends upon the machines being compared. Some machines allow the backing plate to spin rather easily, while others are a bit tighter. Even within the same part number this can occur.
Will it generate the same amount of rotation?
Not generally. The smaller 3/16" diameter stroke limits the potential compared to the 5/16" diameter stroke commonly used in the Meguiar's and Porter Cable units. There are many other factors that determine rotation- stroke size happens to be one of the biggies.
Wow! Thanks a lot for the tips!:xyxthumbs:
(What I noticed from PC videos was that, the backing plate can freely rotate if its rotated by hand!
In DeWalt unit, it feels as if something is kinda giving resistance to its free rotations!)
I looked around and found a seal (that might be useful for sanding purposes) that seems to be holding back the free rotations of the backing plate!
Its the white ring between the backing plate and the fan/counterweight assembly
Its constantly touching the backing plate.
(I guess its meant to fill the gap between the backing plate and the plastic assembly to enable the sanding dust to collect in the bag only!)
I'll try removing it and see what happens!
Thanks again! :D
Thanks again! :D
This is the unit we use at work. I saw you can remove the ring and it will run better as a polisher which is good news. First thing tomorrow morning I will be removing the ring and see how that helps. I know this is an old thread bit thought I'd chime in as I'm on here everyday learning new things.
Sent from my iPhone using AG Online
