Is there a polish that will remove LSP/sealants plus light swirls?
MrOneEyedBoh
Active member
Im looking for a light polish that will remove swirls from a year of washing and also remove the years sealant that I used. There is also two coats or maybe three coats of wax too. The sealant I used was Opti-seal, and its been on there for about 8 months. Im interested in something that will pretty much not dust and can be used with a DA. Non-staining is nice too.:dblthumb2:
Optimum Polish II, Optimum Finish Polish, Optimum Hyper Spray Polish or HD Polish would all fit your needs.
Thats what I originally thought but I came across a few posts ( most likely from newer guys ) that said you need to use something more coarse to remove sealants.. Maybe I read sealant but they were talking about opti-coat? Anyway thanks. I may try that hyper-polish spray from OPT. Looks easy as it can get...
There isn't a sealant available at AG that stands a chance against an abrasive.
Opti coat is a resin based coating product with measurable thickness. It probably can be abraded by any abrasive product on the market, but depending on the aggressiveness of the product you choose, it could take either hours or days to remove it. To remove the swirls on your vehicle and re-coat it, you'd need to abrade all the opti coat off, as the new coating needs bare paint to bond with, it can't bond to the cured resin.
any light abrasive polish will remove swirls and LSP's.
A cleaner polish will do both too, depending on what pad you're armed with..
I have pretty much all the colors from the LC flat line up. I think Im going to try the hyper spray as I said. Very simple and seems like it wont take long at all. Not that regular polishes do, but seems a little easier.
I did my whole truck with the SSR line up and loved how it looked. But it dusted a bit to me...
Megs 151 will not only clean it, but leave it protected as well. It can then be topped with the sealant of your choice. What it can't be however is topped with a "coating", because it has wax in it. (Or what they call "wax" these days, which is most likely a polymer based sealant.)
I know here on AG it's not for sale in smaller bottles but it can be found at ADS in a 12oz and a 32oz bottle. It is a true AIO that can do some serious swirl removal yet finish out amazing.
