They're 3 totally different things. The Mckee's polishing pad cleaner is a spray that you directly use on a dry pad, allow to soak/dwell for a minute or longer and then you're able to rinse it completely clean with a strong stream of water [I lay them on my grit guard and use the hose nozzle] I really like this product and keep it on my shelf.
The microfiber cleaner is a detergent. I've never used this particular one... I do use 3D Towel Kleen and I'm very happy with it, about to put it in my cart right now cuz I'm almost out of it.
Polishing Pad Rejuvenator says you drop a scoop of it into a bucket of water and let it soak, then you clean your pads as normL and they're supposed to come out like new. I've never tried this 1 either, so I can't provide much more info than that.
You have to try poorboys microfiber cleaner one of these days. I like it much better than 3D. Worth the extra cost.
3D Towel Kleen is back in stock, stuff works great and is well under $20 for a gallon, then factor in the free shipping and 20% off and it can't be beaten!
