Is this DA Haze? Black Acura - How to Fix?
Just an update here. I was going to post a picture of a test section I did but it looks there are some issue's with picture/gallery right now. I'll add the pic later once the issue is fixed, but I'll ask my questions anyways.
On my test section I used GG correcting cream with orange pad as a first step. Then I taped that section into two halves and did one side with WGFG3.0 and a black pad. The results are really nice. Obviously the side that I finished has no haze and is much glossier. My understanding is the WGFG3.0 is equivalent to the Menzerna SF3500. I was thinking that since I'm doing a two step correction anyways should I go up to an ultra fine finishing polish like SF3800? Would there be noticeable difference? If going to an ultra fine finishing polish do I need a different pad instead of the black LC pad?
Here is the picture I mentioned in the above post.
attachment.php
I got my hands on some Sonax perfect finish, so I'm going to try that with a few different pads just to see if it's possible to get the job done in 1 step without the haze/marring. Otherwise this will most likely be my combo going forward:
  1. Step 1 will be GG correcting cream + LC orange thin pad
  2. Step 2 will be WGFG3.0 + LC black thin pad
I just had my garage floor done this week, so I'm hoping to finally get this complete over the long weekend.
glad you got the result you were seeking.
when you gg runs out... may want to consider staying with one oem line for their polish and sealants as they are designed to work with each other.
