I also didn't let it cure at all, if I was supposed to. put it on via GG6, wiped of seconds later.
I think when you used 501, it was cleaning your paint more than protecting it. That's why I always recommend a 2 step process with 501/601 to start followed immediately by 105/601 (or 111/601). I use 501 as a cleaner product.
no, I only own 1 DG product, its 501. will be buying 601 or 105 to mix with it, what do you recommend?
I bought it to use on my white Benz because I heard it works great on white, haven't tried it yet. tried it on a Slate colored 2014 Corolla yesterday and it looked really nice.
richy,
Thanks to the info posted by you, with add'l help from Dad07, I've learned a lot about DG and have become quite a DG fan.
I've always used the 1:4 601 mix with my first step when layering, but not the second. If you're doing the mix with both layers, you obviously see an advantage.
Care to elaborate?
Bill
richy,
Care to elaborate?
Bill
Bill, Adding 601 does 2 things:
1) Allows the mix to be topped immediately without the 12 hour curing window
2) Adds longevity to the protection of the other ingredient; in essence makes it stronger.
Kinda like adding the 2 parts of epoxy glue although that might not be a great example b/c 501 or the others do work on their own, it's just they have added protection when mixed with 601.
Hope that helps.
I would like to let the OP know that AG has DG #111 BOGOrops:
Can't go wrong with that. Do not forget the 601.
Dave
