Lowejackson
- Aug 19, 2010
- 270
ONR & IPA also makes a good glass cleaner.
I have done some experiments using ONR as a cleaner. Although I tend to use ONR as a domestic cleaner for most hard surfaces I have also found it works very well cleaning the light oils from a kitchen hob. By giving the ONR about 30 seconds to dwell it does do a very similar job to most domestic APC's with the added benefit of less wiping afterwards. There are of course limits to what ONR can do but for 90% it works very well.
A few years ago I smeared some Menzerna Power Gloss onto some glass and tried water, ONR and IPA to see which did the best job at removing the compound. Water was not that good and IPA and ONR seem to be equal in performance. Obviously glass is not the same as paint but coupled with my experience of cleaning light cooking oils from hobs I would suggest ONR could be an interesting substitute for IPA. This may not be ideal for some very fussy products like coatings but for almost everything else I would say it might work. What I did not try was mixing ONR with IPA, this might be an even better solution
