Issues with Rupes mk2 - 15mm and buffer trail
Jmbrown415
Hi all,
just got my new Rupes mk2 ( 15mm )
seem to to be having big issues with buffer trail. Even on a flatish surface.
any advice? On a totally flat surface the results are insanely good. Jaw dropping in fact.
i ended up using my Torq 10fx with a 4 pad and it more or less sorted the issues, however I really want to use my rupes.
have attached images and appreciate the help.
justin
Looks like some light marring with some hazing. Buffer trails are like holograms, is that your problem?
I gave up on my Mark II, melts pads like nobody's business argh. Sold it at a huge loss to my friend and went back to my Duetto, which only overheats after 30 min. Try a finish glaze with a white pad on the holograms, they may be normal (especially with black) and require that second, more fine polishing stage.
Melts pads? I've had a MKII for about as long as they came out and I've never experienced any pad failure. I use mostly non-Rupes pads and polishes, too.
Something else has to be going on there.
OP - Can you provide a little more info? Product, pad choice, speed, passes, etc. Just to give us some more context and try and diagnose your issue. There are so many variables that it's good to have as much info as possible.
Sorry . Originally used green pad with medium cut green compound. Then finished with white pads and white finishing gel. Wasn't coming out with rupes but when I switched to my smaller padded Torq it came out.
Usual speed , bit more pressure down when compounding but little when using the finishing polish. Just was an issue near the edges , absolutely fine in the middle and straight panels
My Audi is solid black and does have very soft paint so always look for very fine finishing polishes
The Rupes and AG reps I've spoken with all know of the melting pads (melts the black velcro to the backing plate), it's just a result of the excessive heat that the Mark II's can build up in the center of the pad. It looks like the pad is caving in and you can only tell when the pad starts throwing pieces of foam all over the car as it disintegrates. If you haven't witnessed it yet then consider yourself lucky. Literally forced me to sell a near new unit.
Wow, what speeds were you using and what brand pads?
Really unfortunate to hear.
There was a post on fb where it was addressed that the backing plates/pads will succumb to excessive pressure and speeds. Even with their pads and polishes.
So, is it more difficult to get close to that edge with the 15mm?
I have to really make an effort to get my edges done with the 12mm tool. It will do it, but I'm making that pad dance a bit.
I believe you - I've seen a couple posts on here showing that. I am just surprised to hear you sold the machine. I have never run mine above a 4 so I think I'm mitigating some of the heat buildup because of the low speeds.
Pads melt or fail because of:
1. Using 1-2 pads for entire car. Should be using a minimum of 4. I use 6 or more sometimes.
2. Over saturated pad. Pad gets heavy and grabby and more likely to discenerate.
3. Speed on polisher is too high. Speed 5-6 on a Rupes held in one spot too long will cause pads to fail.
Melting backing plate:
1. Polishing non stop will heat up the the tool....like trying to compound an entire car without take breaks to wipe off the panel.
2. Extension cords that are to thin or too long. Use the correct gauge. You don't want to be using 50ft of 18awg Christmas light extension cord. The resistance is too high. The tool heats up, heat travels down the spindle and melts the backing plate.
