MichaelAutogeek
Administrator
- Feb 9, 2022
- 21
FLEX FS-140 Flexible Shaft Set
MSRP: $299.99
The FLEX FS-140 Flexible Shaft Set is the perfect extension to your FLEX PXE 80! This ingenious invention by FLEX gives your FLEX PXE 80 a flexible extension shaft, allowing you to extend its polishing power to any nook or cranny on your vehicle! Polishing behind door handles, between wheel spokes, between grille slats, in and around hood vents, and so many other areas is not a problem anymore! The FLEX FS-140 Flexible Shaft Set attaches to your FLEX PXE 80 using a quick-connect mechanism! Once attached, the FLEX FS-140 Flexible Shaft Set translates the circular motion along the flexible shaft to one of the many polishing heads included in the kit! This means you won't have to worry about being able to maneuver your polisher to polish the surface! Instead, you'll be able to polish any area where you could maneuver a pen! And the flexibility of the shaft means you will be able to reach into niche areas from pretty much any angle with ease! Just when you thought your FLEX PXE 80 couldn't get any better, the FLEX FS-140 Flexible Shaft Set is here to take it a step further!
When FLEX first released the PXE 80 polisher, many detailers were instantly impressed with the versatility it had, allowing them to polish areas they simply couldn't reach with other polishers! However, in their never-ending pursuit to provide detailers with the tools that won't limit a detailer's skills, FLEX created the FLEX FS-140 Flexible Shaft Set to make the already extremely versatile FLEX PXE 80 capable of polishing virtually ANYWHERE! The ingenious design of the FLEX FS-140 Flexible Shaft Set extends the polishing power of the FLEX PXE 80 to anywhere you could fit a pen!
The FLEX FS-140 Flexible Shaft Set uses the same quick-connect mechanism that the other FLEX PXE 80 heads use, making it a breeze to swap back and forth! You won't have to grab a different machine or spend time unnecessarily wrestling with a new backing plate or pad, just pop out the old head, and pop in the new one! No need to break your polishing flow!
There are an nearly unlimited number of uses for the FLEX FS-140 Flexible Shaft Set, but just to give you a few ideas of all the areas that will now be a breeze to polish, here are some ideas:
Behind door handles
Between grille slats
Around wheel spokes/rims
Inside hood vents
Between gaps in emblems
In door jamb crevices
The inside edge of your exhaust
Piano black interior finishes
You've never had as much polishing power as you will have when you use the FLEX FS-140 Flexible Shaft Set with your FLEX PXE 80!
FLEX FS-140 Flexible Shaft Set includes:
Flexible Shaft
Allen Key
Rotary Drive Mechanism
2 Cylindrical Cutting Pads
2 Cylindrical Polishing Pads
2 Cylindrical Finishing Pads
2 Conical Cutting Pads
2 Conical Polishing Pads
2 Conical Finishing Pads
FLEX PXE 80 polisher sold separately.
