Jungle book.... Rescue of a baby and Raised by a wolf - Recue Restorated & protected by KC
kc's
There’s no doubt about it, The Jungle Book is one of those stories that is just simply timeless. It has everything you could possibly want: lovable characters, singable songs, and a dancing primate. But who knew that a bunch of jungle animals and a man-cub named Mowgli would teach us so many life lessons? Not us. But lessons we did learn. Ones like these:
A 3 door Mid Size Prado
Surpassing Its Rivals
Demand for a 4WD with easy-to-ride characteristics naturally grew with the enhancement of user types experienced during this particular time. Gaining momentum from these demands, the Mitsubishi Pajero began to aggressively expand its market share. That was the main reason for the introduction of the 90 series Prado.
have been quite alot OFF the road into our rain forest Jungle
Toyota was aiming for supremacy in all classes, so it developed the 90-series Prado as its final weapon against the Mitsubishi Pajero. In addition to the standard size body there was also a wide-size body version, a sporty 3-door model as well as a 5-door model, which were all easy to distinguish from the outside. The 90-series Prado had a wide and low form, and looked amazingly similar to the Mitsubishi Pajero
asthe results
This is a going to be a collector item or just hard to find here
scratch
The 90-series Prado shares the same chassis platform as the 185-series 4 Runner, but the frame has greater durability than that of the Surf. The side frame on the Prado is constructed of fully closed cross-section members, and the inner channels which this forms are made of thicker steel plate. The inner channel is made of steel plates inside the side frame that reinforce and strengthen the entire frame
badly got bitten by the jungle
even after the correction has carried out....so hard the scratch,,,,impact
adding Swirls
many many hours later
a 50/50% comparrision for your judgement
the door before
tadaaaaaaaaaaaaaaaaaaaaaa
moving to left side
D panell inbetween to door before
door
look at the , amount of scratchhhhhhhhhh prefected
before
tadaaaaaaaaaaaa
final check before coating application
ta da
coating apllied...luster restored......
once upon a time
wet wet
the very next day
happento rain
awsome water beading
tadaaaaaaaaaaaaaaaaaaaaaaaaa
now she is being prep and prepared to face whatever to come
lesson behind
Remember the Bare Necessities
This jungle harmony is nugget after nugget of great life wisdom. Appreciate the world around you, even things as small as the bees who are buzzing in the trees to make some honey just for you. And we’ll tell you something (else) true: the bare necessities of life will come to you.
Brilliant, what compound/polish steps were taken to correct the paint against the bush rash/long scratches? Also what machine/pads/speeds?
Hi Zubair
apologies for not listed down
1. begin washing with OPtimum car shampoo
2.clay with ONR as lube
3. ONR no rinse wash to rinse off clay bar residue
4. Meguiars M101 with Meguiars Maroon Cutting pad on FLEX 3401
5.Polish with Meguiars M205 with Optimum polishing foam pad Green on FLEX
6. wipe down with ONR No rinse wash
7. Final inspection with IPA to ensure all polish oil is remove before coating application
6. OPTI COAT
thanks for asking
Hey Kc have a couple questions for you so do you basically use quick detail spray(ONR) after the m205 to help clean up easier?
My next question is what is your mixture for IPA did you dilute to like 10% or 1:1 ratio?
Thanks in advance
James
Thanks in advance
James
Thanks kuper for asking, it does help but usually i dont, 2 thing to consider while detailing in tropical climate like ours....humidity is high and so does temperature
we have very short correction time! need to do it asap and quickly , swiftly and correctly! thats why you can notice alot of our car are fill with hologram
etcs issue as well
after polish I usually ONR again or QD with ONR...followed by IPA to ensure all polish oil removed prior Application of protection
i Like 1:4 IPA
