? Klasse AIO & OC 2.0
WEST SIDE
Member
I have OC on two vehicles one is white and the other silver that are outside 24/7 and i'm really happy with how clean they stay.I have noticed some light water spots on them and want to clean them up,i know you can use poli-seal but it says it has micro abrasives and concerned it may remove some of the OC,what about using Klasse AIO since it's a chemical cleaner with no abrasives?
Thanks
I have used Klass AIO on my opti coated car once. It did a good job polishing up the car. You will be fine if you use it.
I've wondered about this as well. I think both KAIO and poli-seal are both very mild, but not really sure if one is less aggressive than the other.
Thanks for that,wasn't sure.
They are both mild but poli-seal does contain micro abrasives.
