BobbyG
- Dec 29, 2009
- 13,211
If I use KLASSE all in one can I use a diff glaze then KLASSE glaze? Like megs glaze #7?
Yes you could but good old #7 provides only appearance but no protection at all...
No. KAIO is the base for for KSG. KSG is not a glaze. It is true sealant. KAIO is a chemical cleaner with a base layer of protection and is great under almost anything. But KSG needs the proper surface to bond to as a sealant. The oils and fillers in most glazes would be counter productive.
If you want to use a glaze, I would suggest doing KAIO, 2xKSG, Glaze of choice, then a wax to seal it in.
You can put anything ontop of KAIO right afterwards, but if you apply a coat of KSG you'll need to wait 12 hrs for it to cure.
