klasse and a pc
jeepe
Can you use klasse aio and a pc since klasse aio is a wipe on wipe off cleaner
Most definately, just remember Klasse goes on thin, or its a PITA.
Work AIO in (2X2 area) until it's almost gone, then wipe with MF.
I did the AIO and the SG with my PC had fantastic results, yes make it very thin. I did the AIO with a 4" orange pad then buffed it off with a wool pad. Put the SG on with a red 4" pad and buffed it off with a wool pad. It looks really good. I put Frenzy over the top.
6559
URL%5D
URL%5D
the pad becomes the abrasive part, and the AIO is a chemical cleaner. Same results using Poorboys Pro-polish and some other chemical paint cleaners like Pinnacle and P21S.
What pad would you recommend for klasse AIO?
If there are any defects in the paint, then I would go straight to an orange pad. It probably won't remove all the defects but it will do better then a white pad. If you use it after polishing, then use a white pad or finer.
How about the lc green pad?Is it almost similar with the white pad?
I can't recall exactly, but I think it's in between the orange and white pad. I use Menzerna FP2 as minor paint correction, and then use the Klasse AIO.
