Klasse High Gloss Sealant Glaze?
Sunder92
I got this a while ago and plan to use it for my spring detail, so I've been been reading up on it around the forums.
What I got is that you should put some in a spray bottle and you should wipe it and buff right after you spray.
Is this correct?
Would a foam applicator pad work? Or is spraying and buffing the best choice?
I've never used a sealant with such low viscosity and don't really know how to do about this.
Is this correct?[
Use a damp foam applicator to apply thinly and remove one panel at a time.
Congrats on the purchase of Klasse SG, or KSG as I like to refer to it as. Here's a simple way to properly use KSG for best results for application and removal:
-get yourself a bowl and add some water in it.
-I prefer a square cotton applicator, foam seems to not slide across the paint as well.
-find a small spray bottle, like 4 oz or so.
-dunk the applicator into the bowl of water, then pour some KSG into your small spray bottle.
-wring out the cotton applicator, making sure its damp but NOT dripping wet.
-depending upon the size of the panel and/or section your working on 1-2 sprays is more than enough. Wipe the KSG in from left to right, up and down, work it in real good.
-WIPE OFF RIGHT AWAY! This product is acylic, NO need for it to set up, anyone who says you leave it on the car does NOT know how to use it.
-Keep the applicator damp, it makes spreading KSG alot easier, easier is key when using KSG.
-DO NOT USE ON GLASS, its VERY hard to remove for some reason.
-Once your done the car will look great but the key is a 2nd coat, that needs to be applied 12 hrs later as KSG is acrylic it needs time to cure, 12 hrs is the shortest amount of time, the 2nd coat really makes the paint pop:props:
To help maintain inbetween coats of KSG I like to make up a gallon of quick detailer using rinseless wash, adding 2 oz's of KSG into a made up gallon. This not only makes clean ups easier but you also end up adding another layer of KSG, albeit a thin layer for sure.
Thank you. This was very detailed and helpful (:
Is this correct?
I used it for the first time a couple of weeks ago. I sprayed it onto the applicator pad (I used a microfiber applicator) and then applied it to the car. The first coat I applied and then wiped off almost immediately, the second coat (applied the following day) I let set for 30 minutes and then wiped off. Either way works. I used Sonus Spritz to help remove any trouble spots.
Apply it thin, thin, thin. You will like the results, I did. Washing the car now any grime just slips right off. Good luck!
2nd coat makes a huge difference, I have not made up the QD yet, but maybe I will after my Sonus Spritz runs out.
The Sonus is an acrylic like the Klasse SG and the Klasse AIO. It was made to work with Klasse products.
Sent from my DROID RAZR using Tapatalk
Listen the man. He knows his stuff when it comes to Klasse. It was this method that mede me like klasse even more.
2 great products. I have both and use it with klasse. They both work very well.
Would Meg's QD and QW not work? I have 4-5 bottles of QD and 2 bottles of QW and I kinda wanna use some of it up before buying new stuff.
I have used both with KSG and they work just fine.
Klaase,
The qd mixture is just a gallon of water and the two ounces of KSG correct?
Klaase,
Oh no, you use your favorite rinseless wash made up as a QD, like 24 oz of DG, 2 oz of KSG and then top off the gallon jug with water. Now, the KSG will settle somewhat in the jug and/or spray bottle you put it in so you'll have to shake the bottle good before using it.
YOU MUST USE YOUR FAVORITE RINSELESS WASH WHEN DOING THIS! I call this "FrankenDetailer".
LOL! Thanks Klaase.
I used Klaase on our old Saab convert. which was silver. Great tips.
KSG is great on silver, makes it shimmer! While we're talking about Klasse I should mention that KAIO is fine to use on glass but unlike KSG it can be left on and taken off later if you want, no need to hurry things along but its a good idea to keep the applicator pad damp when using KAIO though.
[/FONT][/SIZE][/QUOTE]
Interesting... Can you elaborate your RW dilution rate and just
what method you use to achieve this?
Feed back please. :buffing:
I used the KAIO on glass and am really happy with the results.
Absolutely, cleans and protects and since its so easy to use and apply, once a month keeps your windows cleaner and in some cases the use of wipers is not needed even.
