Rsurfer
- Jan 26, 2007
- 14,163
- 26
Would this product work for the wheels? The ones that aluminium and have a clear coat.
It will work, but a paint coating will last much longer.
To help maintain inbetween coats of KSG I like to make up a gallon of quick detailer using rinseless wash, adding 2 oz's of KSG into a made up gallon. This not only makes clean ups easier but you also end up adding another layer of KSG, albeit a thin layer for sure.
To make my hybrid version of a "Detail Spray Wax":could you mix KSG with a spray wax like Meg Synthetic Spray Wax, or would you stick with a QD as the base? Not sure if there would be any benefit by doing this, but curious if anyone has tried it and what the results were.
Either way I will be making up a bottle soon!
I haven't used KAIO or HGSG on my Camaro ... yet ... but I do intend to at least use it on the rims. if not as a base for some Collinite.
I used the twins on my previous car and I noticed that it was VERY anti-dust, anti-static after 2 coats of HGSG.
Collinite waxes are so durable, you really don't need a "base". I'd save some time and simply choose to do one or the other. You can't go wrong either way.
Can KSG be applied immediately after AIO? I know KSG needs 12h between applications but haven't read anything about letting the AIO cure.
