Klasse Sealant Glaze..
OK, I understand about multiple coats, but what about a redo in 6 months? Do you just wash carefully and put another coat on or do you have to remove the layer that is there (and if so, how?)
I just a rinseless wash, ONR isn't going to strip your LSP. You can wash and apply around coat of SG every time.
It is really up to you. When I washed it, it looked as good as when I first applied the stuff so I didn't bother doing anything else.
After six months of wear & tear...
there may be some remnants of KHGSG 'round-and-about.
Then...For the "redo":
-I'll first just do a "regular" car-washing/drying session;
-Next: Perform the "baggie-test" for any claying that may be needed;
-Then, it's the swirl-finder-light's turn.
Depending on that outcome:
It's either back to a swirl remover polish followed by a KAIO application---Or just the KAIO application
followed by the KHGSG.
***I just preformed a rinseless wash. ONR isn't going to strip your LSP. You can wash and apply a coat of SG every time if you wish.***
I need to proof read more. :eek:
Use Sonus Acylic Glanz after washes and it will prolong the life of the KSG as it was designed by Sonus to specifically to bond to KSG. It's worked wonders on my wifes car. And it's currently on the fall roll back sale, good time to pick some up.
Sonus Acrylic Glanz Spray Sealant, Sonus paint sealant spray, spray paint sealant
Thanks for the tip...
Sent from my SCH-I535 using AG Online
I will be ordering this tonight to take advantage of the sale.
