Klasse twin
adrenaline
Just applied 1st coat based on klasse act recommend wowo workflow. It look great for my serena 2014.
Look forward to applying second cost and colinite😁
It is great looking stuff on white. In my eyes it makes it look like a polished rock. Very durable too, so you will like it a lot. Get another two or three coats on and it will really knock your socks off. :)
Back when I used to use the Klasse twins we used to try and layer 5-6 coats of SG an hour or so apart. It was Klasse that got me bit by the detailing bug back in 1999. I bet that first summer-fall I put 50+ coats of SG on my white Jetta. My family thought I had a problem.
I find the best durability was to use the spray on/wipe off method. Once done I allowed 4-8 hours to completely cure and then a second level. Its darn bulletproof with two coats. I also found the Sonus Acrylic Spritz to be rock solid for use after a washing session. A great booster and gloss additive.
Hi ebg18t, just wonder if you can see the difference of 50+layer, do you see it get thicker coating?
I don't know about ebg18, but:
•Even if there was actual film-building occurring
through/by 50+ SG-applications:
-I probably could not (unaidedly) see ~ 0.0134" (7/508 in.)
That was 10 years ago. I honestly don't think there was a difference after 4-5 coats. But I worked evenings back then so I detailed my car a couple times a week.
