Kranzle K1122 Question
YankeeFan
Driving myself crazy trying to decide which electric washer I should get.
I want it for my cars but also to remove mold from siding and some small areas on concrete.
Has anyone owning this 1400 psi pressure washer tried It on concrete and siding? Enough power
to clean them, maybe after pretreatIng with a detergent?
Thanks,
Howard
although it isnt the same, i recently decided to drop the $100 on an electric greenworks (1700 psi)...mainly for ease of use considering the wife using.
so far, i am impressed. i bought the greenworks circular scrubber ( thinking my Briggs unit would be too big)...again, impressed.
considering my gas unit is 2500 psi...this little unit is impressive.
1400 psi, maybe slightly less power, but going into it knowing it limits...i think it should do you fine.
Thanks,
Howard
You’d want more psi for siding and cement. I got a 2300psi Ryobi electric and it does OK
PSI alone shouldn't be the sole determiner for pressure delivered and efficiency. GPM is just as important. That Kranzle unit has a good GPM to go along with the 1400psi and is more than sufficient for what you want to use it for.
