Coopers ST
Active member
- Nov 23, 2013
- 1,277
- 4
I use a gg6 with a 5" plate. What is the difference in the SDO and the thin pro pads. They both are evenly priced andseem evenly matched only one has a center hole for heat.
SDO pads are great. They work fantastic on long-throw and 8mm polishers.
That's a hard choice. Probably the SDO pads. They're a little bit thinner/lighter than the uro-tecs and thinner than the LC HDO pads because they don't have the rubber interface. The reason I prefer them to thin-pro pads is because of the center cooling chamber. Plus, the SDO pads are an excellent value.
I do like the orange thin-pro pad and the megs maroon thin foam pads BUT IMO the GG6 has enough power that it can handle the ever so slightly thicker foam of the SDO pads while still getting the advantage of increased pad rotation on contoured panels. The SDO pads are also provide a much smoother buffing experience than thin-pro pads.
That's all just my opinion/experience.
