Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
Lake Country ThinPro Foam Buffing Pads exclusively at Autogeek
What can I say?
Thin is in!
For comparison
The Meguiar's thin foam discs on the left and the Lake Country thin foam pads on the right.
Meguiar's foam discs measures 11/16 of an inch thin or 17.5mm thin if you prefer the metric system.
The Lake Country ThinPro pads officially measure in at 11/16" or 17.5mm as stated by David Patterson at Lake Country.
As you can see by the below picture the Lake Country ThinPro look to be a tick thinner than the Meguiar's foam discs. This minute difference could be created by the thickness of the Velcro, or even adhesive or a natural bow to the pads after being boxed and stored. Big picture is the trend for foam buffing pads for free spinning random orbital polishers has for the pad to get thinner and thinner and the new offering from Lake Country validates this trend and now you have two brands to choose from.
By stacking 3 pads from each brand next to each other the small difference becomes more visible.
Fact is you really don't want or need to get any thinner than these pads as there is something to be said for having some level of mass or material between the paint and your backing plate. If pads were to be come any thinner it might be neccassary to use them with a foam interface pad and then you've moved away from the entire idea of using thin foam pads.
More comparisons
Lake Country 5.5" foam flat pads on the left and Lake Country ThinPro foam pads on the right.
Pad options...
Meguiar's offers three foam discs, cutting (maroon), polishing (yellow), finishing or machine waxing (black)
ThinPro foam pads are available in 5 flavors, see the graphic below for specifics.
ThinPro pads are available in 5.5" diameter and 6.5" pads.
On Autogeek.com
Lake Country ThinPro Foam Pad System 5.5 inch
Lake Country ThinPro Foam Pad System 6.5 inch
If you want to stick with the original thin foam pads because they offer a little more cushion and safety for people new to machine polishing, here's the link to the 5.5" Flat Pads
Lake Country 5.5" Foam Flat pads - 7/8" thin
What can I say?
Thin is in!
For comparison
More comparisons
Pad options...
On Autogeek.com
