Layering waxes
Souldetailer
Hey Y'all,
Do you layer waxes and why? I have a fine layer of Collinite 476 on my vehicle and plan to do a second coat tomorrow. Do you believe that an additional coat on another product will enhance what you have already applied. Different waxes that is. Thanks for your input.
Peace,
Darrin
Hey Y'all,
Peace,
Darrin
Applying two coats of the same wax will work as the second coat may cover some areas that was missed the first time.
Most waxes have solvents to keep it spreadable and will remove some of the first layer. Using a spritz of water on each panel will help to dissolve the solvent (spit shine).
IMO you should stay with the same wax if you want to layer. A lot of guys will lay down a sealant as a base coat and top it with a carnuba wax to give it depth.
I like to layer my waxes. I use a sealant 1st then a wax and in about 3 to 5 days RW and then put a 2nd layer (max 3rd). Additionally, I think with a 2nd coat the gloss and depth and wet look really stand out.
[QUOTE=Rsurfer
I love this idea
Layering waxes has only one practical result...it ensures equal and total coverage. Layering doesn't prolong durability imo. As far as changing the looks...that's subjective.
Carnauba for me :)
Waste of time, energy, and product.
Do one coat, take your time and do it right - call it a day.
My thinking is the rubbing and buffing not only puts new wax on but it also takes some of the old wax off. Does that make sense?
Just like doing wheels off detail , do it once and right ^^
Slow and steady!
