LC plate kit for the Flex
DaveT435
Active member
There are two very thin washers, or shims, that come with the kit. They have to go between the adapter plate and the backing plate. I assume you use both of them with both plates. Can anyone confirm this for me? Watching the video of them changing out the plates I don't see them being used.
Feed back please
Why not with the other smaller plat from the kit, it fits nicely?!?
:xyxthumbs:
You should use both shims/washers...for whichever LC plate you use. They help reduce heat transfer b/w drive head and plate/pad.
I also oil felt ring as Mike recommends to reduce friction heat.
When you use the shims with the 4 inch face plate it doesn't mate with the backing plate correctly. Only use the shims with the 6 inch.
