LC Wool Pads for PC
Old Pirate
Member
Just wondering if anyone have use the LC form wool pads 6.5 for the DA/PC that AG has for sale? I have the UDM and would like to try it out. Has anyone bought this pad yet and use it? Would like some inform on these pads.........Thanks.........Angelo:cheers:
wool pads are never as good on a DA as they are on a rotary...i find more success with an orange pad or yellow pad that i do with wool on a PC/DA
Right pad- wrong tool, get a Makita and keep the PC for final light polishing and applying waxes and sealants.
I have the foamed wool 6.5 polishing / buffing pad just ordered
2 more, as for me they produce far better results than the foam and
do not cake up at all, I use this on the UDM.
I also have the Lambswool 6" leveling pad but have not
tried it yet, will soon with power gloss compound and UDM
:cheers:
Thanks Ong~Bak for this information, i have been looking at this for awhile and was thinking of order 1 to try out, might call AG to see if anyone there has use it..............Angelo
I have used the foamed wool and UDM -it works, but I actually have gotten better results with either an orange or yellow CCS foam pad. On the rotary -now that's a different story. The wool pad worked a lot better on the rotary.
Buy it, if you do not like it I will buy it from you.
I use the purple foamed wool LC pad with Menzerna Nano P0 106FF
and I will not go back to the white foam, you will not be dissapointed.
:cheers:
Thank you , will order one on my next order......:cheers:
What would be the recommendation for a wool pad under microfiber on a UD machine??
I do this for AIO, polish and LSP removal, after wiping off the majority/excess product with a MF towel since the bonnets have minimal surface area. I have a PC, not UDM, but same concept.
:cheers:
:iagree:
Nano Polish (105FF) will remove 2500 grit, for light surface marring and / or surface finishing, cut 2.5 - gloss 5.0 for LSP ready use a primed White (softer less dense foam (70 PPI) with a light abrasive cutting action ) or an LC CCS purple foamed wool pad - 1100 RPM
