kovalchuk71
- Mar 4, 2009
- 193
How did you all learn how to wetsand? I would love to learn from a professional, but being in NC I really dont know of any around, and I dont want to be fed false information....Any suggestions?
i learned the basics in a body shop, practiced on my own car and finally taught myself polishing and swirl removal
Be sure that the surface is nice and clean. Soak the area with IPA using a q tip. Apply several thin coats and allow to dry between coats. If you apply one thick coat it will not adhere properly.I had a deep scratch which I wiped with IPA and then used the paint pen to repair it. After four days, I used 2000 grit paper to remove the color bump. Unfortunately, the paint came off and the scratch is now back. Previous to using IPA, I had waxed it with M16. So either M16 withstands drugstore bought IPA or the dealer bought touch-up paint does not stick well. The color match is absolutely perfect though.
In the past, I have used similar technique but that was with different paint and also used the brush which came with the paint bottle. Needless to say, the pen does a lot better job than the brush but I wish it had not came off after light sanding.
Any suggestions? Should I have waited longer than 4 days?
- Vikas
