Leather Help?
First my guess is since the issue is isolated to one area and Matt has explained very thoroughly what the problems could NOT be... I'll say it's the exception to the rule issue. That is while the majority of Honda cars are sold without any issues... once in a blue moon something goes wrong either at the beginning of the manufacturing process or somewhere down the line and that's the exception to the rule or the exception to the normal high quality put out by Honda.
Interesting information guys, I'll definitely give that a try.
I read somewhere that mere soap and warm water would work, or would you not suggest that?
Using warm water and a little soap, even a simple hand soap is what I'll recommend for sticky interior surfaces.
First it's a very safe approach and you want to work safe when it comes to interior surfaces like leather covered steering wheels.
Second, it's a simple approach, sometimes keeping it simple is better than all the complicated approaches put together.
Third, if it doesn't work you can always get more aggressive.
Forth, while your hands are not leather like you find in your car you've probably noticed at time or two in your life where your hands were dirty, maybe even sticky, and a little warm water and some hand soap restored them to like-new again. You've probably rarely if ever whipped out the APC to clean your hands.
So yeah, for sticky issues I'll try a safe, simple approach like a little water and some soap. Mix a little in a bowel or cup, dip a microfiber towel into it, wring out any excess so you don't drip water all over the car interior and then wipe the steering wheel down.
I don't currently have an APC at hand, I'd have to order it.
I'm thinking using an APC is going to end up with extreme results, that is it's either going to fix the problem, (that's one extreme), or it's going to make it worse, (that's the other extreme).
Before doing anything aggressive I'd take it to the dealership in a very nice, friendly way. I'd share this thread on the Autogeek forum, maybe just print out the first page and show or use a highlighter to mark the little numbers on the upper, right hand side that shows how many pages this thread is going and all the suggestions you're getting.
What kind of car is it?
2015 Honda Accord Coupe (the one in my profile)
If I owned a 2015 Honda Accord I would be a member of this forum (AG)), and I would also be a member of the HondaAccordForum.com or the DriveAccord.net forum and then in the general section for 2015 Honda Accords or in the car detailing section I would make a post to see if anyone else has come across this specific issue.
With all the thousands of Honda Accords that have been sold over the years and all the thousands of 2015 Honda Accords that have been sold in the last year, if there is any chance at all that this issue has happened to some other Accord owner then there's a good chance there's already a thread about it documenting the problem as well as the solution.
Wait... did a quick search on Google using these search terms
2015 honda accord sticky leather steering wheel
and found Matt has already taken this approach but alas... no solution so far on DriveAccord.net with 6 replies.
Leather Steering Wheel Help? - Drive Accord Honda Forums
One thing for sure, looking down the list of search results for the above search terms and it looks like sticky leather in Honda's is an issue. I see threads on pretty much all the Honda make and model forums for sticky leather and sticky leather steering wheels.
This means this issue has probably come up at your local Honda dealership as other customers have more than likely brought purchased Honda's back for remedy.
Your dealership is either aware of this issue and has a solution or my try to simply make you go away. Print out the search results page on Google too... above all... be nice when you go the the Honda dealership. Stress that it appears to be an ongoing issue for Honda and it's really time to find a remedy. Maybe vinyl covered steering wheels?
Hopefully dirt or grime is the issue. I'm thinking it's not, but hoping it is.
If this doesn't work, I'm going to contact the dealership because there's NO way the leather should wear this quickly and have a different texture/feel from one side of the wheel to the other.
I'd try the simple approach first, then re-try the Pinnacle Leather Cleaner & Conditioner as it is a very good AIO but it's not going to fix the impossible to fix as this seems to be a very common problem. I read through a couple of the other Honda threads on multiple forums and I'm sorry to say I did not find a single issue where someone posted a sure fire fix.
I did read a lot of recommendations for Lexol and I did read one person suggest the issue came from a mechanic with brake fluid on one hand that was the root cause of the original problem. I don't know if there was a mechanic that did cause the problem with brake fluid but one thing for sure, brake fluid is some nasty stuff.
Good luck Matt and do all Honda owners over the entire world a huge favor and if you do find out what the specific problem and solution is to fix the sticky steering wheel updated this thread to help others into the future.
Thanks Mike! I appreciate the thoughtful response and all the time you took to research this! I definitely tried the DriveAccord route, but figured some of the detailers here might have some more ideas. I tried more Pinnacle Cleaner/Conditioner last night and it didn't seem to get rid of the tacky feel.
I'll try a wipe down with slightly soapy water tonight and update everyone with my results. I've already contacted the dealer to have them on standby in the event that I can't fix it myself. Thanks for all the help and support, I'll definitely keep everyone in the loop. How great is the AG community, huh?!?! Awesome stuff guys, thanks again!
UPDATE:
So I just got home and based on the various advice from others and from the legend that is Mike Phillips (honored he responded to my thread), I decided to go super conservative with the wheel. Since everyone here at AG loves pictures and documentation, I figured I'd make a mini summary of my process here complete with a few pics.
I started with 1 bowl of warm water with 2 small squirts of hand soap and 1 bowl with just water (separate MF towel for each).
bowls.jpg~original
I made sure to ring out both MF towels until they were just damp, not wet. I hit the wheel with the soap towel and then the water towel. This was the end result (you can still clearly see the right side of the steering wheel is MUCH darker).
After%20Soap.jpg~original
Then I went over the wheel with Pinnacle Leather Cleaner and Conditioner. I followed the directions, shook well and applied a small amount to another clean MF towel and applied it to the wheel one section at a time, then wiped clean with another towel. Here was the end result:
After%20ConditionerCleaner.jpg~original
Unfortunately it's still the same as it was before. The rest of the steering wheel is more conditioned, but the right side remains tacky and clammy. I posted the short video below for those who are interested. I'm going to be contacting the dealer tomorrow to schedule an appointment, I'll let you know how that goes. Thanks for all the help guys!
https://youtu.be/QKDxKu8pkpg
That looks like a miss match piece of leather. Has it always been darker than the rest of the wheel? Good luck with the dealer.
If dealer won't honor it try a product called afta or try some saddle soap.There maybe a open campaign warranty on it,the dealer will know good luck.
This👆🏽
Great job on the documentation. You can really see the difference in your pictures. Make sure to show them to the dealer in case the lighting prevents optimal viewing at the time you're there. Good luck.
UPDATE: Went to the dealer and the sales rep who attended to me didn't see the issue and even when I showed him the pictures I posted here he wasn't buying it. He then drove the car out into direct sunlight and I spoke with him and a tech and the tech is the one who admitted he saw a difference.
I'm sure it helps that we're good friends with the dealership owner, but I still wasn't too happy with the way the one attendant acted like I was crazy. But I'm not going to complain too much, at the end of the day they submitted a warranty claim and ordered me a new steering wheel free of charge.
I spoke with the person who sold me my car as I was leaving and he assured me the new wheel would be defect free and apologized for the rudeness of the first attendant. So it appears no amount of detail work could have helped me here. It was simply a problem with the leather.
I'll post picture once I get the new steering wheel installed. Thanks to everyone on AG for the help!
-Matt
That's great news in the end!👍🏽
I can't believe that person tried to say there wasn't a difference between the 2 materials on the wheel! It so obvious on that picture, wow what a jerk..
I'm glad you got taken care of, as you should.
Now that they're going to replace it with a new steering wheel, take some Meguiars D101 APC full strength w/a wire brush to that spot and see if that finally gets it off!
Lmao j/k😜
