@Evo, so how would you classify the "fog lights" on an S197 Mustang GT? I have to say mine are anything but oval/flattened. And as a matter of fact, when I'm running all 4 lights at once, people flash their high-beams at me... I'm not sure if it's really blinding them, or they're just not used to seeing all 4 lights on at the same time. But I can say with certainty, we Mustang owners, call the lights in the grill "fog lights".
Paul, nice Mustang!:xyxthumbs:
So how would I classify your fog lights? That depends on their performance. Do you have any garage wall shots that you could post so I can take look at the actual beam pattern? Despite them being a round lamp, if they are genuine Ford part (and not aftermarket) they should have the typical fog beam that I mentioned. And most importantly, if they are aimed correctly, there will never be any discomfort glare to other drivers. If your are occasionally getting flashed then perhaps they are too high.
Remember, a fog beam is supposed to light up the foreground underneath the low beam. And while your fog lamps are in the grille at the equal height to your headlamps, I believe its safe to assume that many owners might mistake these lamps as a driving lamp and reaim them higher. Which is a mistake.
Here is a image for reference to illustrate the positions of the low beam and fog beam combo. A fog beam should never be aimed anywhere near the horizontal line that the low beam occupies. If there is any incidental light that falls above that line then that light should not exceed 550 candela.
Here are two lamps I have on my test bench. A reflector halogen fog lamp from a Cruze. And a LED fog lamp from the newer Mustangs.
This is the reflector lamp.
And as you can see it has the typical fog beam. For what its worth, this particular lamp is a cheap aftermarket one from China. It surprisingly has a decent beam however I have not tested the actual GM part for comparison. OEM lamps are built to higher standards and conform to the DOT FMVSS108 photometric regulations.
I've added a red line to indicate where the DOT has specified where glare falls onto the eyes of drivers. The incidental light of this fog lamp (weird V pattern) shining in that region is well under the photometric maximum.
This is the OEM LED fog lamp for the Mustang.
Since it is a projector it will have a superior sharper beam. And also a MUCH wider spread as well. Projectors will always control light much better than a reflector.
My concern with Don's fog lamp is that its the wrong tool for the job. And it will cause discomfort or even disability glare to other drivers. Since its a spot beam, the round halo surrounding the center peak intensity will fall onto the eyes of drivers. Even if it were aimed at the correct position which is 4 degrees down from H-V.
