Let's see you pressure washing station/setup or work in progres.
DanaDetailingPros
Active member
I have the Active 2.0 and I'm in the process of making a station. Just ordered a stainless shelf and Cox reel. Just at the patch and paint stage now. I ripped out a built in work bench that came with the house a while back.
One of these pictures is what I'm planing on doing. Minus the CR DI setup. Maybe one day. I know a few of you have some setup's so show them off here:Picture:
The following was 3 years in the making, and six months of homing in on the specifics. I say 3 years because if I knew what I know now, I would have done a wall mount instead of a mobile unit when replacing my old Karcher K2. But I have thoroughly enjoyed learning about all this stuff and being creative with how I wanted it to look and function. (Yes, I know how something looks doesn't always have a lot to do with functional performance, but I'm a visual person and if you think about it, I wouldn't be detailing cars if I wasn't concerned about how something looks.)
Three years ago, I bought a Kranzle K1152 (K1122) and its been an absolute tank! I didn't want to go back on performance, so choosing another Kranzle was a natural one. This particular model is the KHD10/122, which actually flows more than the OG-only K1322, and the K1622. I also went with a Cox Reel, MTM hoses and fittings and a stainless steel shelf. I already had Mosmatic gun, wand and nozzles, so these transferred over.
The wall I chose already had a Mosmatic wand holder installed, so this was the natural location for the setup. First job was to paint the wall to provide a clean backdrop.
This is a solid pre-cast concrete wall, but I didn't want to install directly to this. I decided to use a stainless-steel kitchen backsplash panel I bought at the hardware store. I then laid out the setup, measuring and marking the location for the mounting holes. This sheet then became the template for drilling into the wall, but its obviously also there for aesthetic purposes.
Installation of shelf, machine and reel..........
I then drilled and secured the machine to the shelf using anti-vibration clamps, same for the whip line................
The braided stainless-steel hose was a bit of trial and error, but one of the more satisfying elements for some reason. I ended up ordering 3 different lengths to allow me some leeway in fitment. This is the longest 600mm version...............
Probably the hardest part of the project was getting tradesmen to turn up, I could have finished the install 4 months ago otherwise. I needed both water and power added to this location, the plumber came first and at least allowed me to start with the installation. After being di.ked around by the electrician, I ended up calling someone else. The 15-amp power point was installed just last week and was the final piece of the puzzle.
In my case, I don't need a DI system, so I saved some money and time in that regard. Having said that, I don't dare add up how much this all cost me.
As I mentioned, this was an enjoyable project that I'm super happy with the end result. Even just looking at it makes me smile, and the functionality is brilliant.
Love it DFB!!! What size JUMPER did you go with? I'm thinking I need a 3 foot.
DFB, it doesn’t get any better. Outstanding work.
Here's my setup, little bit more humble, but a 10x upgrade from what I had before.
Active VE52 pressure washer
CR Spotless with downtube conversion
MTM pressure washer gun
Griots BOSS foam gun
Northern Tool reel
Flexzilla pressure washer hose
Flexzilla jumper hose
Shutoff valve on the braided input hose
I used a 3 foot jumper hose. If you go with the 1.5 foot, it ends up looking a bit goofy.
One thing I would recommend, and something that will help with jumper hose length, is to make sure the gap between the reel and shelf is nice and tight..............within reason though.
You still want to be able to turn the handle without clouting your hands on the shelf, but keeping the reel tucked under the shelf makes for a cleaner looking install. Some examples I looked at in the research stages that had too much gap didn't look as clean. Keeping the layout nice and tight will also mean the 3 foot jumper hose will be more than sufficient.
I didn't make a specific set of measurements for this initially, I just mocked it up on the bench until I was happy, then made measurements to suit.
Some very nice setups. I was just looking at some CR spotless water systems yesterday. I actually was about to start a thread about it.
I have many cars (6 mustangs and 2 daily drivers) and usually would wash them at a self carwash then finish it off at my shop.
My question is, can I purchase a CR spotless water system and just move it outside my shop when I want to wash a car? I have a water spigot outside.
Most of the time I use detail spray, but that doesn't work great on daily drivers, and I'd rather skip the self serve carwash and people when I can .
Thanks for any help!
Sent from my moto g power (2021) using Tapatalk
Yes!
Scroll up amd look at my setup.
My cr spotless is on the little wheelie cart it came on.
A bit more flexible than a wall mount, in case you need to move it.
I just grab my hose, walk over to the garage, hook it up to the cr spotless, and get to work.
The CR Spotless is probably a top 3 improvement item for me the last couple years. So nice
Yes!
Great too hear. Do you use a pressure washer, or just a garden hose? I do have a foam cannon, but haven't really used it yet.
I'm still researching this CR spotless, seems fairly straightforward.
Yep, pressure washer and foam cannon.
Look into the down tube conversion.
Basically, after you use up your first resin cartridges, you buy a set of $40 tubes that you install.
It let's you buy generic loose resin that is cheaper and lasts longer than the cartridge.
Much appreciated, I'll do some research.
I need to take a photo of my Karcher 3.99, that's my pressure washing station.
Had issues with the pressure washer sliding. I searched just about everything to find a solution. I came across this bath mat that has suction cups on the bottom and the perfect texture for grip on the top. I couldn’t of found a more perfect solution! And it was only $10
Cox reel should arrive this week!
