Lexol cleaner/conditioner?
otruba_843
I saw it at the local wally world. Is it any good? My BMW leather is in great shape for 4.5 years. The car still has some new car smell and it always smells like leather. Is the conditioner good for normal maintenance like once a weekend? What about the cleaner for clean seats or dirty ones? I have the soft upholstery brush for the porter cable and it works great for the leather.
I will say that the conditioner definitely doesn't have a great/pleasing smell to it. I also don't think it's meant to be applied that frequently -- probably more of an every couple months type of thing. Would it hurt? Probably not... but is it worth it? Probably not... That's just me though.
Lexol's leather cleaner is probably the best value you can buy. It's a gentle cleaner that's suitable for routine cleaning, is inexpensive, and widely available. Based on your comments that your seats are in generally good condition, this cleaner is a good choice.
Lexol's leather conditioner is also a good product, but not appropriate for most auto seats. That's because modern auto seats are covered leather, which means they have a finish over the leather that will not absorb the conditioner. Lexol's leather conditioner is good for use on unfinished leather as is commonly found on home furniture and apparel.
To protect your leather seats after cleaning, you want to use a leather protectant. This is basically a dressing on the finish of your leather.
I use Lexol on my dash, VW leatherette and GMC leather and have no problems with them whatsoever. On the leatherette the surfaces are very slick for a day. Your butt slides a little until you get into your normal driving position. What I found is that using a microfiber pad works better than a towel for applying the conditioners and cleaners, no matter what the surface.
Last year I pitted Lexol and CarPro PERL on my VW interior; Lexol won. It resisted dust significantly longer than PERL on my dash. I suspect PERL could have won had I layered it, but time is $$$ and didn't want to go that far.
Which Lexol product are you referring to? Their product line includes various treatments for leather and vinyl.
Good tip! Thanks
Good tip! Thanks
Vinylex for leatherette and dashboard. Leather cleaner and conditioner for the real stuff.
It sounds like you're satisified with your results, which is great. I use Lexol Leather Cleaner for my seats and Lexol Leather Conditioner on my home furniture. I think they offer the best quality for the price.
But if you really want to fully maximize your results, I suggest the following:
Continue to use Lexol Cleaner on your leather, but replace the conditioner with a protectant. Lexol does not offer a leather protectant, so I recommend Leather Master Protection Cream.
For vinyl, Lexol's Vinylex is a two-in-one product that combines a cleaner with a protectant. Generally, you get better results with products dedicated for a single purpose. Not that combo products don't work well, they are a good convenience for most consumers who want to get things done quickly. But if you really want to maximize results, then separate solutions are more effective. Lexol does not offer separate products for vinyl. So I recommend Meguiar's Quick Interior Detailer Spray as the vinyl/plastic cleaner, and Aerospace 303 Protectant as the vinyl dressing.
I have used both recently and it's ok I guess. I'm going to keep looking for something better though!
Terrible!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
:iagree:
Lexol is horrible. The cleaner can't clean anything greater than a smudge. The conditioner is a little better, but you need to apply, let it sit, and clean off with a MF.
I've tried it on many different brands of cars. One of most underperforming products ever.
PM me. $5 for shipping and I will send you Lexol Cleaner and Conditioner 70% full for free.
Lexol is a gentle cleaner for routine care. For a bigger job, I would go with Leather Master Strong Cleaner. What is your preferred leather cleaner?
My go to is Ultima Interior Shampoo Gel.
Dirty stuff gets Leather Master or Leatherique.
Lexol isn't a terrible product and I have actually used the cleaner wipes to rremove makeup from a visor.
If you are cleaning your leather every weekend then I would suggest a 3-in-1 like Lexol's 3-in-1. It will give you the light cleaning and protection you are looking for. If you know your leather is coated like domestic leather upholstery then any product made for vinyl will work for lightly cleaning and protecting leather. The only areas that are really going to benefit from a conditioner on coated leather are seams and perforations in the leather.
Sent from my SAMSUNG-SGH-I897 using AG Online
I use them to maintain the leather in my Charger. But when I run out I'm going to try something else, mainly becuase of the smell. Lexol has a strong, pungent smell that lasts for up to a day. I hate driving the car the first 24 hours after I apply the stuff.
Yeah, Lexol's conditioner is pungent but, makes me think that some leather essential ingredients are getting into the pores of the leather. Have you tried wiping with a damp MF to remove the excess product,which may reduce the smell?...
As far as a product line that is pretty much oderless try Leather masters. I use their products exclusively on leather in good condition. I have noticed that their products are temperature sensitive, at least when trying to remove dye transfer.
Collinite's leather wax is really good also and not temperature sensitive but can be too strong for some leather that is worn/un-coated.
:iagree:
I had this thought too for a bit and then I switched over to MF pads rather than any type of towel. Working the product generated much better results, particularly with Vinylex.
I plan on getting 303 this year. Thanks for the tips and the validation!
I've had good results with Zaino Z-9 and Z-10
Z10 smells AWESOME,but I wasn't terribly impressed with the looks or durability of it. I don't think the seats in my G8 are true leather though. The seats did feel good however,and the product didn't transfer to my wife's clothes.
Lexol seems to be a love/hate product on every forum I visit.
Exactly. Its a cleaner. It needs agitation. I use a cleaning scuff pad and scrub it pretty good. Wipe off excess Looks like new. Then apply leather conditioner of choice.
Sent from my Dell Streak using AG Online
