Lexus headlight restoration and Opti-Guard
gofast908z
I got contacted by someone from the Lexus forums (referred through Ryan Tornio, thank you) for a headlight restoration on his Lexus IS250. These lights had slight oxidation, but worse was an attempted repair carried out sometime in the vehicle's past with less than stellar results. Extra time was required to undo the previous attempt at correction and then restore the clarity and protect the lenses. Foglights were also bad, extreme # of rock impacts. Majority were sanded out for a better finish.
Once completed, all lenses were sealed with Opti-Guard, made by Optimum Car Care. After sealing with this, it basically creates a new clear coat on the surface to permanently protect it. These lenses should never fade or need correction again.
Here are the pics
Finished pictures
Thanks for checking out!
You always do great work, but never tell what you used in greater detail.
Thanks!
Process was damp sanding on the PCXP with Trizact 1500 then 3000.
Compounded with GI white wool pad and M105.
Polished with LC orange and M105, then LC white and M205.
And like in the title, sealed with Opti-Guard.
Nice job Gofast. Lots of pics! Would be nice to see some during pics but I am just being picky now. Thanks for sharing. The Opticoat did good.
has anyone seen how long the opti-guard will last on headlights
