Lighting Techniques for Light Colored Paint
Porsche Pilot
There has been some recent traffic on the forums here about lighting and lighter colored paints. As the owner of three silver cars, I thought I would share a tip to find defects easier.
Disclaimer: This is what works for me. If you have a better way of operating then please, always use what works for you. :)
If you think it is hard to find defects in silver paint it's even harder to photograph but I did the best I could. These pictures have not been enhanced in any way and are straight from a Canon Rebel T2i set to auto.
1. This is the drivers door on my Arctic Silver Porsche 996 C2. I keep her in the best condition that I can. Currently she is wearing a coat of Blacklight and topped with V7. My garage is fully lit in this shot with overhead fluorescents. The tape is a focus point for the camera:
Things look pretty good and the paint shines nicely.
In this shot, I have added supplemental lighting with my Infratech Color Matching Light. Things still look pretty good:
Here is where I get jiggy with the whole process. I darken the garage as much as possible. Overhead lights are off and the window shades closed. I place a small, single head halogen on the floor. I place it at angle to the rear of the panel I want to inspect. In this case, the drivers door. Halogens on stands are too high to get the effect:
Now, I will inspect the panel at an angle, facing the light source. Angles of the light and the angle of your view are important. You will not see anything if the light and your view is straight on.
Wait, what is this? A scratch!! I cannot see this scratch in daylight or in any other lighting except for the sequence above. The scratch in question has been caused by magnetic track numbers. I need to wet sand it out and have now applied numbers to my windows to alleviate the problem.
Hope this helped. It works great on white paint too.
Awesome awesome awesome post. Thanks Ed! I had planned on doing something like this but for the Brinkmann only. Thanks for taking the time to put this together. Very informative!!! I will soon have a silver RX350 in the family (I pretty much already do) and this will be very helpful when I go to do a correction on it.
Do you correct with the lights out as well? Or just for inspection?
Tape! The missing link! Been using my finger up until now... But tape should make handling the camera much easier.
On silver and white, I correct in the dark. The floor halogen provides enough ambient light to see what I am doing.
Thanks for sharing Ed.
Working in the dark sure does make things easier to see, and particularly on light color cars as you have pointed out.
Awesome. I found it really hard to find scratches in my silver car. Will try out this method.
So a scratch that size would require wet sanding? I guess I have couple spots i have to hit with wet sand then! Is it generally a good idea to wet sand a scratch on the bumper and then compound it out? I've seen a lot of video's on metal panels, but not on bumpers.
If you have a DSLR, just learn how to manually focus the camera and you don't need any "tricks" to pick up defects :props:
That particular scratch is a bit too deep to correct without sanding. The picture doesn't really show its depth. I would tread lightly on sanding out a defect on a bumper. It is a must to measure the paint so you know if you have enough clear to work with. I would certainly try to polish it out first but you also must be careful to not wrinkle the paint with too much pressure and speed.
I really only use the tape method when I am using a handheld light source like the Brinkmann and I want to capture a particular defect. I can't manual focus and hold the light at the same time. Maybe I should wear one of those miner lights on my head to leave my hands free.
Ed, I cant say it better than Alex did! Fantastic post!
Thanks for the kind words Jim. The only downside with my lighting technique is that I can't utilize all the lighting mods you and I did in our garages!
Thanks for the tip.
The key seems to be lighting from a single direction at oblique angles so you see the shadow of the scratch. Otherwise, they get washed out when other light.
I highly recommend you dispense with that lighting technique and your car will be scratchless. Glad I could help. :D
TL <--- if I can't see it it isn't there
Thanks for the tip.
Right on Bunky! You phrased it exactly the way I should have in the first place.
Excellent idea! You think just like someone who has worked for the government for too long. : )
I forgot to mention one other point. You will notice that the one lamp halogen is sitting on the floor. When I get to the higher panel sections, eg roof, trunk and hood, I bring that one light with me. The light came with a spring clamp. I attach it to a microphone stand. I can then manipulate the light to the desired angle. I love the dual halogen stands but find that I cant always move the light heads around enough to get the right light.
+1 I found this out correcting my white F-150 about a month ago.I used every light source possible and the single halogen on the floor and viewing at an angle was the ticket,couldn't believe how much i could see doing this in a dark garage.After I was finished with correcting i still had some deep RIDS I could see with light(left them any way) but couldn't see them outside unless the sun was very bright and you looked really hard to find them.
Ken
I really need to pick up a photography book. I have a DSLR... I just suck at using it.
No worries; I was fortunate enough to have learned the basics on a 35mm SLR that didn't even have autofocus as an option. If you start forcing yourself to only use the camera on manual mode you'll learn a lot really quickly.
