I just wanted to make this thread to help out anyone who has purchased a bottle of Liquid Souveran recently.
Finally Liquid Souveran Wax achieves the Pinnacle of Perfection. Liquid Souveran Carnauba Wax has the ease of a liquid wax with the protection and
Here is my story. I purchased 2 bottles of Liquid Souveran recently and both bottles arrived and they were very watery and would not constitute into a cream like liquid wax. I tried every way possible to shake the product up in the original bottle and it would not shake into a cream like I knew it should be. So I called Autogeek for some tips and was told that its totally normal for the product to be watery and separated. To just shake it well and continue to use as normal. So I tried this with one of the bottles and while it did work it was impossible to use correctly. As you could imagine, the product was oily and watery and would just roll right off of the applicator pad. When I did get it applied to the paint, the haze was more difficult to remove than I knew this product usually is. So I was unhappy with leaving this wax in this state and happily using it.
So after I pulled out all of the shaking stops. Shaking for 30 minutes straight, warming the bottle, ect ect.
Finally I decided to pour off the 16oz bottle into a BIGGER 32 oz bottle and capped it off.
32 oz. Meguiars Generic Spray Bottle
With the product in the bigger bottle , I shook it up and down (not side to side) and within 1 minute the product reconstituted into a very cream semi thick liquid (slightly thicker than Wolfgang DGPS). After the product shook together , I poured it back off into the original Pinnacle bottle.
Tested and works... perfectly. Problem Solved.
This was such an annoyance to me that I did a forum search and did not see a specific thread answering the question on what to do with a product that wont shake up right. So I decided to make this one as I noticed a lot of the PBMG wax's and sealants are coming delivered without being mixed up and need a lot of shaking. Anytime I run into this issue again, atleast I know what to do instead of trying to shake the bottle all day without results (to the point that my hand was actually sore).
