•The vents are part of what GM/AC Delco
called: ”The Astro Ventilation System”.
{It was on many GM makes/models...
ca.1968-72}
-This system eliminated the triangular
shaped window vents—the ones that
not only supplied outside air to the cabin,
but also made it real easy to break into
the vehicle.
As is the case for most over engineered
vehicle components—this ventilation sys-
tem wasn’t always a “closed loop system”.
As such:
After the enormous amount of Customer
complaints; coupled with the costs associated
with warranty work: this system was dropped
from GM’s 1972 model year Impala, along with
many other vehicles in their portfolio.
{Sure enough/magically:
those little (side) vent windows re-
appeared on many GM makes/models.}
Good questions. I was more interested in whether that is a real 4-barrel carb on the top of the engine and what happened to the air cleaner.
I see a few donk's around my area. Some of them have a high level workmanship and are really unique. I wouldn't drive one, but I appreciate the creativity and workmanship that went into modifying the vehicle.
Follow the money. Wing windows were useful when A/C was not prevalent and for smokers who preferred not to use the ashtray, among many other things. They added complexity and cost to the manufacturing and after-sales maintenance and customer satisfaction level (vis-a-vis repairs, water leaks, etc.). The first Arab oil embargo hit in '73 and car designers started seriously thinking of aerodynamics as a way to increase fuel efficiency. They were also a convenient entry point for break-ins.
As A/C became a mainstream option (instead of a luxury option only), the push for more fuel efficiency, increased competition from Japan to cut manufacturing costs and cars became quieter where wind noise became evident the move to "flow-through" ventilation progressed and wing windows seemingly disappeared overnight from cars, a little later from trucks.
