Surprised Meguia'r has not solved the dusting with their M110 compound. I do agree with you on the cut and finish but the dusting is what keeps me from using it. Which is where Ultracut and Cut Max have it beat in that regard. I find ultracut to finish out slightly better than cutmax but that is paint dependent as well.
Tried a sample of Jescar Correction Compound and it ended up in the the trash. I am not saying it was bad, as i did cut ok and finish out well. Just saying it didn't do anything to wow me from other compounds.
3D One is fine but can be a bit oily to wipe off. Perfect Finish to me gives a better finish over 3D One.
Just goes to show that everyone finds a preference on what they like.
Pretty much nailed it right here.
These days absolutley zero tolerance for dusting... to many good products out there that you don't have to deal with that.
I agree also that Ultracut cuts harder and also finishes down better than Cutmax. Pretty wicked cutting compound.
In which Jescar can't even remotely shake a stick at.
Ultra Cut, Cutmax and Menzerna 400 are all light years better than Jescar
What machine do you use?
I might pickup Jescar medium very soon. I can get a small 4oz sample from my main supplier.
UltraCut contains a cocktail of fully diminishing abrasives, which correct heavy defects, while producing minimal hazing. Combine it with the CARPRO cutting pads (wool, flash, cool) or microfibres for extremely effective and efficient defect removal. Drop down to CARPRO orange polishing pad and you can finish down hologram-free even on the most sensitive paints.
Did you ever try The Last Cut Mike?
I'm a minimalist so to speak so i'm always looking for one product that i can use for compounding and finishing. What 3D one claims to do.
Maybe i should just pick a compound + polish combo and be done with it.
Cutmax for instance as never given me any wipeoff/dust issues and i've used it a good amount of times now.
Never used last cut. I am pretty set with what I have at the moment. The good thing is you can get CarPro stuff in 8 oz bottles just like Sonax.
At the moment I am enjoying testing out the Dr. Beasley's surface primers.
Do you think Ultracut can be used as a 1 product paint correction system on most paints?
do you think gyeon primer on a foam polishing pad will easily clean up any haze left from Ultracut, in most cases?
Yes, on most paints you can. Now on something soft like Nissan black, you're going to get micro maring but Ultracut paired with the right pad will give amazing results.
^^ This.
I'm a bit OCD and don't mind blasting over top of UltraCut with Essence. For me, it's a well worthwhile step given Essence serves as the base for CarPro Ceramic Coatings which is what I typically use so there's the main reason. It will finish out extremely well but if you're REALLY after the WOW! factor, polish it after with essence. Not much more than 1-2 passes will be needed.
