Looking for alternative ways to clean floor matts...
Eldorado2k
Hey guys, I'd like some input on what should be 1 of the most basic things a detailer does, and that's cleaning floor matts.
For the longest time I've done it the basic way, and that's to spray some diluted APC and hit it with a scrub brush, quikly go over it with the Shop Vac, and finally mop it up with a folded terry towel. And that's always worked ok... However it tends to be alot of work, especially when I'm usually doing it on the ground.
But lately I haven't been quite satisfied with the level of clean that I usually achieve, and I've been wanting to reach that point where no more dirt mops up but I'm starting to think I may be fighting a losing war.
This is what I usually deal with: After scrubbing maybe 2-3 times, 1 whole side of my 16x24" terry towel folded into 8 sides is fully loaded with dirt I've mopped up off the matt.
Sure I'm making progress, but...
...But after another 2-3 rounds of scrubbing, now both sides of the towel are saturated with dirt and it seems like it's not going to stop anytime soon...
Now to the average Joe, or someone who couldn't care less this would suffice because it certainly looks alot better than before.. But I want to get the matts fully clean and would appreciate not having to work myself to death in order to do so.
To make things a bit more frustrating than they already are, I bought a couple of Cyclo brushes for my DA, and they've made absolutely no difference at all. After trying them out a couple of times now, these brushes are seriously underwhelming.
I have to use it on speed 6 just to ensure the thing spins, otherwise on something like speed 3 they absolutely don't spin at all.
I've marked it. I can see if it's spinning or not, and it doesn't spin on speed 3 unless of course you apply less than no pressure and feather across the carpet, but who does that. This is how 1 brush looks after 2 uses. Is this normL? It looks almost beat to death...
I've come to realize that it's not the scrubbing that's a chore, it's the mopping that's a PITA. Especially when it's never ending. But as far as the scrubbing goes, I can do a much better job than these brushes on my DA and that part isn't even hard. But there's gotta be a better way.
I stopped after loading up both sides of that towel and I could've kept going... Looks better, but I'm still not satisfied.
So what are some alternative methods? I'm ready to look outside APC. Quite frankly I'm thinking about taking the other matt to the laundromat tomorrow morning just to see if I could avoid this chore of cleaning matts.
These matts are used in my fathers truck, but they're actually original floormatts from a 1998 Cadillac, so they're quality matts with plenty of beef and thickness to them.
I don't have an extractor. I don't have a tornador. I don't see how my steamer could help.. Please advise on any possible bare bones methods or alternative cleaning liquids. Please be specific if you can and don't just tell me to check the local janitorial supply because I've seen that recommended too many times. Lol. Thanks!
I use a different DA brush attachment, this one www.autogeek.net/hd-carpet-brush.html. I attach it to my old porter 7424xp and I leave it on...it's now my designated carpet brush. The bristles haven't flattened out, and I've used it almost every day for months. But the real game changer for me was the use of Citrol 266. I dilute it around 4:1 with water, and I'll spray it on the really dirty spots of the mat. I then use Optimums Carpet and Fabric cleaner diluted 3:1, spray it on the whole mat, I hit it with the DA brush, and I tell you my friend, the dirt and grease is GONE! I mean vanished into thin air. For some reason, that combo is like a magic trick. I've gotten some seriously hammered mats to look almost new again, customers can't believe it. I no longer get scared when I see a dirty, greasy disgusting mat! The Citrol just breaks it down so well, and so fast...most of grime ends up in the brush. Give it a shot, I do not lie! Oh, and it probably works just as well using any APC, but Optimums Carpet and Fabric cleaner is some pretty amazing stuff as well...together there lethal!
Have you thought about using a power washer on the lower setting? Pre-treat it before hand, agitate and rinse away. Most quarter washes have matt hooks for cleaning them, it's worth a shot
I don't have a dedicated system for mats, I kinda change it up depending on the mat, (the quality of the mat, the level of filth, type of filth, color)
Without extractor I think the most effective thing I do for really bad ones was Presoak with apc or degreaser, agitate with flex 3401 on speed 3 and carpet brush (never stalls) then hang up vertical and spray rinse with power washer. I have a big plastic table top converted into a mat station, I cut slots in one end to hold clamps to clamp the mats for power wash. I've found that even when agitating with brush or vacuum it helps to be vertical as debris falls clear of your work.
Yeah I've wondered how many towels can one stinking floor mat dirty up before it's clean, I usually have given up before finding out.
Hot water extractor has saved my back and arms a lot of grief.
Sent from my SM-G930V using Tapatalk
Power washer with a 40 degree nozzle. From no closer than 12 inches. I never had a pressure washer, I used a soft rubber hose and made my own fanned our spray pattern by pinching the end of the hose. You can watch the dirt and sand being sprayed away with the hose. The pressure washer is way more effective, but you can ruin mats if you concentrate the pressure in one area.
I have probably cleaned thousands of the exact same 1998 Cadillac mats you have.
When i detailed cars I used a body-filler spreader to remove the majority of the water than shop-vac to suck up the remaining water
For sure keep the power washer away from the mats. My Worx hydroshot only makes 320 psi max, so it's no where near the power of the quarter wash sprayers. I plan on using my Worx hydroshot to clean my 3 season mats when my WeatherTechs go in in a couple weeks.
My neighbors already think I’m crazy when I wash my Weathertech mats on top of the snow Banks in mid January. I like the idea of the Worx PW. Perfect for mats, door jambs, engines and light PW needs.
Weathertechs have relegated all my carpet mats to permanent (year round) storage. After scrubbing carpet mats for 10 years I gave up and went to plastic. I’ve grown to love their ugly, bulky, utility looks.
Try the WeatherTech cleaning/Protectant combo...game changer
My FIL’s Black Weathertechs in his F150 are less than a year old and are trashed. I’ve tried Meguiar’s Super Degreaser and a stiff tire brush and they still look horrible. The fine pebble/wrinkle texture traps all the silt like dirt and nothing seems to release it. I’m actually going to test a new product not offered by AG. We will see if that works. I will have to try Weathertech’s combo if the new cleaner doesn’t work. Thanks for the recommendation.
Buy the product made by WT for WT
Floor matt makes me picture a ‘too much tequila’ night.
The best way would be a steamer and instead of a da, try one of the brushes on a rotary polisher. What I find works out great is to spray down the mats a few times and let it sit while you do the rest of the interior, then you come back and deal with the mats after the cleaner has had some time to work on the dirt a bit. What I've also done is spray the mats down with a strong citrus based cleaner and then toss it into the washing machine.
Yet another reason I want to pick up a used washing machine to hook up in the shop for dirty deeds.
I started out without a steamer and extractor in the beginning as well. I would use the pre treat method and proceed to using a stiff carpet brush to scrub the area, mop up the area using a towel, and finish up by vacuuming.
This technique worked, but it has its limits on how bad the condition of the carpets and floor mats. If I was dealing with just some dirt in general and no really bad stains that's been there for quite some time it wasn't a problem. The moment I started to encounter gum, food spills, extra soiled big patch areas, crusty hardened dirt, and any liquid or substance with coloring then that technique can't get the job done.
I purchased a bissell pro heat , and a McCullough 1385 steamer based on positive feedback from AG members on here. The addition of these tools have helped me tremendously with getting better quality results. Don't know how I was gonna to attempt to clean vomit on carpets or vomit on fabric seats without the steamer to kill the bacteria and the extractor to lift the soil from the carpets fibers and the liquid from the seats padding/fabric surface.
My process for cleaning floor mats and carpets are
Vacuum
Spot treat individual areas with appropriate cleaners
Steam focused area
Brush with stiff brush
Extract
After spot treatment done
Vacuum again there will be lots of sand lodged in there sometimes
Steam whole floor mat to use the heat to break up dirt
Spray cleaner all over floor mat
Brush whole floor mat
Extract
Rinse and repeat til satisfied
I'm aware everyone does things differently to get the desired results so I'm not saying this is the only method. For whatever reason I been getting more interior work and have put more time in honing my interior skills and knowledge. This is the system I have decided on to use for the majority of situations. There will be some interiors that are extra dirty and will encounter different defects like paint correction but for the mean time this system works for me.
I usually just spray mine down with some APC or Spray n Wash or whatever laundry spot cleaner we have Shout, Oxy clean ect and throw them in the washing machine on a hot water setting and allow them to air dry after. Works perfectly and no the little rubber teeth under the mats don't break off in the wash.
I'm glad the washing machine method works for others but I would never do that
I second this. Pre-soak, agitate, pressure wash, find a place where you can hang them up to dry.
I use about 5 drops of laundry detergent with the hottest water my sink puts out and mix it in a spray bottle. I spray down the surface, agitate with a stiff brush and blot away...rinse and repeat as needed
Larry from Ammo has a video on it and it works well. If it's crazy bad I hit a spot with APC and then go over it with with the laundry detergent. I use dye and fragrant free as well
BAM
I third this too! Vacuum, Pre-treat stains, spray down the whole mat with my carpet cleaner solution ( a mixture of ZEP High Traffic Spotter and ZEP Citrus Degreaser ), agitate thoroughly then pressure wash, hang to dry. I'll do this first thing for max drying time. If needed I'll put them on the floor of my van with the floor heat on, dries out in no time!
Mike
