Looking for an after wash topper spray
The griots used Carnauba too so i think it would play fine with wax. I’d personally use it instead.
Optimum car wax and Griots spray wax will play nice.
Optimum and the 3-1 probably your best protection route.
To use Griots Poly Gloss it is recommended to use their BOSS Foam cannon or another similar hooked to a pressure washer. It can be used in foam guns hooked to your hose or a pump foam sprayer also.
Griots say the 3-1 is more hydrophobic.
I use Griot's Garage Poly Gloss in my IK hand pump w/o a problem
He’s done with the BM, looking for better protection.
Sorry I should have read his entire post. In that case you could try jescar bead it. It is just as easy as beadmaker and will get you better durability and water behavior. It is not as glossy and slick as beadmaker. I went back to beadmaker due to my base lsp is durable enough that I would rather have more gloss and slickness in a topper then durablity since your applying it after every wash. I went back to using beadmaker i have not found anything comparable for a topper.
I haven’t heard of 3D Bead. I’ll have to check that one out. Do you believe it plays well topping over waxes, like Jescar Power Lock or Adam’s paint sealant?
Could always stick with something in the Adams Family (pun intended).
Since you like to wax, I’d suggest Meg’s D156.
Always a good option. D156 never gets old.
I use BM as a drying aid after every wash, very easy to use and it helps with my LSP . The slickness and gloss a plus.
Because of this your car looks stunning EVERYDAY
dg aqua wax, tw ice spray wax ,eagle one wipe and shine, anything from meguiars or mothers.
I’m guessing OP wants a bit more protection than Elixir, assuming it doesn’t last much longer than BM (?).
If so, it's hard to beat Optimum Car Wax, only spray on with patent UV protection.
Tip #348 for spotting a detailing junkie: a friend recommends a product and you decide to pick up another unrelated product from the same brand “too”.
Haha indeed
I’ll have to look at some videos on YouTube, because I think I remember someone I watch feature this product. Auto Fanatic, I believe was who it was.
Yup, I have an MTM PF22.2.
Ofcoarse that works I don't have a power washer so use various IK hand pumps. Griot's Garage Poly Gloss is going to be one of your favorite products to use but PLEASE,don't drink it, no matter what your nose tells you
