looking for Single pad and polish?
wn1998
I am not looking for 100% correction. I am looking to just get some minor correction (car wash induced swirls) on daily drivers. I want it aggressive enough to cut water spots and maybe 70-80% correction but am looking for a single Pad/polish combo that will give me good results.
I typically do the following in about 1.5 hours 2x a year:
Bug remover
Wash (ONR)
Clay
Polish
Sealant (usually blackfire wet diamond)
I appreciate your feedback.
Megs D151 sounds like what you need.
Adjust pad to the car, same product...
I've been using 205 with a cyan hydro tech pad a lot recently. Cuts pretty well & finishes out nicely on most paints
I think you would get great resluts using WG Uber on a white pad.
Last weekend I use it along with an orange pad and looked amazing just with that step
Sent from my SAMSUNG-SGH-I747 using AG Online
Sonax Perfect Finish + Rupes Yellow Pad is the one step combo to beat right now. Fabulous results every time.
What color car? Getting too aggressive with a pad will leave marring.
Sounds like a job for Menzera PF-2500. You didn't state whether you wanted it to have protection in it. if you want an all in one then Meguairs D-151 would be the go to and you change the level of cut depending on the foam pad used.
