Not really if you add it all up. GC takes 1oz per gallon, DP is only 1oz to make 3-5 gallons.
DP is 32oz for $16, GC is $10-$12 for 64oz BUT you will be using 3-5 times as much product. The value is in the higher end products as most of them only use 1oz for several gallons.
The DP label says use 2-3 ounces per 5 gallons of water. I never use more than 3 gallons of water to wash a car. So I guess it's safe to assume that 1 1/2 ounces of DP to 3 gallons will do a marvelous job and is also the best value.
However, I'll have to use up this garage sale find first. Im the MAN
Dubbin I am not sure about your math but I do know what people are paying for MEGS Gold Glass and how I mix it - I use 1 ounce in 3 gallons of water in a 5 Gallon Bucket to wash most cars. I am able to buy Gallons all the time for under $10.00 from a number of sources and sometimes under $9.00 a gallon. Half Gallons (64OZ) are readily available for $6.00. so typically I am spending 8 to 10 cents or less for car wash chemicals to wash each car. I have never had bad results with this ratio whether it was in a bucket or a foam gun. SO I am sticking with MEGS GC !
