Looking for Tips, Tricks, and Techniques with the PC!
KJW Detailing
Well some of you know what happened to my PC during first use...so while the PC is being sent back and a new one then being shipped to me, i though this would be a good time for me to further educate myself with the PC!
I have watched the movies but they apperantly didn't help me...haha...so im looking for help from the ones on this site with experience with the PC!
I think an appropriate starting point would be with the pressure being placed on the PC during use! I would like to further breack down the pressure placed on the PC with the pads being used and compounds/polishes...LC CCS Pads...
Yellow, Orange, Green, Blue, Grayish-black, and White...and then the full line of XMT Products...
I think this is a good starting point...
Thanks!
There is no given amount of pressure to be used with any combo. You just have to try different amounts and see what works. Just let up a little when you hear the RPM's bog down.
Place the PC with pad on the car, see how it feels, now push down just slightly, you want to maintain that amount of pressure where it just slightly bogs yet is still working mainly under the weight of the machine. Like 5-10 lbs of pressure at the most.
I polish on speed 6 (Edge pads, don't try this with backing plate pad or your pad will turn into a U.F.O. lol), and move about an inch per second making overlapping passes, figure 8's etc.
Thanks surfer!
So i guess 5-10 lbs. isn't alot of pressure...
I know that i can hold the PC lightly enough that the DA rotation seems to be free of any pressure restrictions...at the same time if i just hold the machine and the pressure is that of the machine, i can tell small restriction and pressure...after that, im just not able to determine the pressure that i am putting on the PC...
Ok so being that i have the LC CCS Pads i guess i should never have the speed on the PC above 5?
Move One Inch Per Second (i understand this but)...does this hold true with any pad and compound/polish combination (ie. yellow pad and XMT 4 or blue pad and 360)
roadrunner1659 said:
Thanks surfer!
First of all you had a defective machine, so maybe the pressure you applied was not typical of what the pc could handle. Applying up to 15 lbs. should not be a problem. Iv'e run the pc with 15lbs. of pressure for hours with no heating problems. Using speed 6 is also not a problem. I don't think pc would put a speed 6 if it would cause damage to the machine. Yes, very slow for polishing like the video shows. Hope this helps and good luck with your new machine. I know how disappointed you must be.
thanks! i'm just trying to better understand the PC! so why not just ask those with the experience!
All I was doing, was answering your question about speed and stating a fact. I apologize if you took it the wrong way.
Roadrunner...use the wieght of the machine and just a touch of down pressure to begin to get the feel of it...you can polish at 6 at times no problems....
what I do is I polish at 5 ..thats all you really need...move the polisher at like 1 inch per second....what I do is I move ahead 6 inches...then polish back 3 inch so I double polish the area....
so what you do is go 6 forward and three back and 6 forward again...
this has worked great for me..it may take a bit longer but you work the polish a few times on the first run....
I do this horizontal first....>>>>>>>>>>>>>>>>>>>>>>>>>>>>
then I do it vertical ^
^ doing the same thing
do a 2x 2 area at a time....
take your polish and apply to the pad...spread the polish on the area at speed 2 ..then boost it to 5 work the area..on the last sweep go 6..just do a smooth sweep on 6 no need to back polish....
if you have a bad area..like a scratch.. work the area at 6....checking your work....do not hold on just the scratch area work area around it also so not to just cut in one spot.....feather it ...
always shut the machine off if you need to lift it off the paint...less chance of pad coming off...or polish fling.....
Just take your time..rome was not built in a day....
once you develope a technique it will be much faster...but when first learning take your time.............
first words you hear from a beginner is The swirls are still there.....only cause they did not let the pad and polish work the paint...or wrong combo....
Take your time and FIND what works for YOU....
AL
if you want to get an idea of 10-15 lbs of pressure....take your pc to the bathroom scale and push down till it reaches that weight. <<<read this somewhere else but forget who....
Mechanical v. chemical....do you let the pad and force be the swirl remover or do you let the product do the work....I think you need to rely more on the product and worry less about pressure. I think that time is another factor that is often missed....the time to allow the product to break down, cure, set, or what ever can make a great difference in results.
Thanks for the reply's everyone!
RSurfer i was thanking you to for ur responce...and i was just saying that this is why i am asking, so that i can learn from poeple like you whom have more experience with the PC.
Depends on the pad, a backing plate type pad like LC, eventually it will become a UFO at speed 6 lol, speed 5 is better as the velcro and backing sometimes start to come undone. Edge pads no trouble at that speed.
so at this time, my understanding seems to be that in general, its not about the pressure you apply to the machine during use...but rather the pad and polish combination that is actually doing the work...
Generally speaking, what can we do to minimize dusting besides cleaning and priming the pad?
Yeh. But, some pressure may equal some more heat which is what causes polish to break down.
Bottom line is your first few cars are going to be trial and error. It's frustrating but a fairly quick learing curve.
Here's something that might help at first. Time your polish breaking down (almost disappear) with a kitchen timer. Time it again, etc, etc. Then set your timer for each area you do. You'll be in the ball park with this system and will eventually get a feel for it and toss the timer.
maybe then in all honestie...my car would be a good first car to do b/c its brand new and all it needs is at most XMT 1...so i wont really need any pressure...
anyone think this might be a good idea?
What color is your car? Have you looked at it under some Halogen lights? Because its new doesnt mean it has no swrils or marring. If its in good conditon then go ahead with XMT1 and LSP.
The color - Fiji Blue Pearl
Car - 07' Honda Civic (soft clear coat)
I haven't had it under halogen lights but it has very light hairline scratches/swirls from washing (i wash correctly but i over wash)...and im not sure what marring looks like...
