Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 12
- Thread starter
- #41
I picked up the Napa air tool lubricant. I have a Napa store only a few miles from me. Only $6, not bad at all. Just a quick question, how often should I be lubricating the felt ring? Is it before every use or periodically? Does the lubricant last awhile on the felt ring? Thanks!
I lubricate the felt rings on the Flex 3401's in our garage anytime I'm swapping out backing plates.
If you use this tool as a full time detailer and punish it then probably once a month it would be a good idea to add 2-3 drops or spread a thin film over the face of the ring.
If you over do it you'll find oil being spit out as you buff, do keep in mind, sometimes...
Less is more...
