Makita 9227c vs Flex PE14-2
trerc
I currently have the Makita and have really been thinking about getting a Flex both for the lighter weight plus the ergonomics of the unit really looks great. Any users out their that possibly have experience using both that can compare the 2?
Both great machines. They're somewhat similar and the only difference I see is the Speed settings. You can polish a car quicker with the makita then the Flex. To polish my car with 3 steps only(swirl removal, polish, sealant) takes a good 8 hours( if you do a proper job) Carnuba wax and glaze I put on by hand. The makita, with the proper pads maybe half the time.
Yea theres a weight difference, but hold the flex for 8 hours and it will feel like a ton!
I'm in the same boat as you. I really like my Makita, but the benefits the Flex has over it convinced me it would be a smart purchase. So I decided to go ahead and pick one up as soon as it goes on sale, but who knows when that will be.
They are both rotary polishers. Why would the difference from one to the other save you half the time?
I have both the Makita 9227 and the Flex PE14-2
Some specs....
Flex PE14-2
  • Length - 15 3/4"
  • Height - 4 3/4"
  • Weight - 5.6 pounds
  • Power Input 1400 watts
  • Price - $379.00
Makita 9227
  • Length - 18 1/2"
  • Height - 6 3/4"
  • Weight - 8.8 pounds
  • Price - $225.00
The Makita 9227 is second from the let and the Flex PE14-2 is at the far right.
As you can see the Makita is quite a but larger than the Flex. The Makita is larger in all respects but don't think it's a huge and unmanageable machine because it clearly isn't.
The Makita 9227 is a powerful well balanced machine with variable speeds and a soft start once the trigger is depressed.
The Flex PE14-2 is smaller, lighter, well balanced, variable speed, and more ergonomically designed. It's just as powerful but because of the smaller footprint it's easier to handle, more maneuverable, and easier on the user.
The Flex is quite a machine and lives up to all the hype but it costs $150.00 more than the Makita. The Flex is built like a tank and with all that it still only weighs a little over 5 1/2 pounds.
If the additional cost is of little consequence then the Flex is the obvious choice. If you use a machine for several hours a day as a living then again, the choice is the Flex..
If you're a weekend warrior or seasoned professional the Makita is a very well build and reliable machine and will last a long time. It's been around for quite a while and has a proven track record.
I'm assuming he's comparing to the Flex DA instead of the rotary. Cause I don't see why the Flex rotary would slow you down compared to the Makita.
I LOVE the Makita. The only reason I haven't bought a Flex rotary is because I'm scared that when I start using it...I won't see the point in the purchase. The Makita is a very solid polisher. I wouldn't trade it for the world. I've used it for years and years 6 days a week full time. The only thing I ever have to do to it...is change out the power cord every year and a half or so.
:wow:Feed back please:confused:
From what I've learned, using the flex rotary, your passes are slower compared to a makita or a dewalt. From my experience using the 2, the speed of the polisher, mixed with the how fast or slow will determine how long it takes to break down the polish/compound. I've learned my polishing technique from the junkman.
Watch the videos and you'll see why The flex is double the time compared to the makita.
Sorry I tried to embed the link but it didnt work...if you can embed these videos please do so.
PART 1
Polisher Speed of Movement - Part 1 - YouTube
PART 2
Polisher Speed of Movement - Part 2 - YouTube
PART 3
Polisher Speed of Movement - Part 3 - YouTube
Forgive me in advance if I do not consider the junkman the most credible source on the subject.
That being said, both polishers are capable of turning the same size pad at the same rpm (up to 2100rpm, I wouldn't go above that anyway).
The only variable left in that "equation" is your arm speed and polisher weight. Arm speed should not be governed by which polisher you are using.
Otherwise, the 3.2lbs extra might help you break down polish on horizontal panels, but gives you more of a burden on vertical panels. I would think this difference would balance out the time savings.
From beginning to end....I concur!
Everyone has there own technique and learned from someone. I followed his technique and had success.
i skimmed through the videos and the junkman was using the flex 3401, not the flex rotary. so maybe thats where the confusion is coming from. i just bought the PE14 myself and trying to pick up a few tips on it.
Your right, :doh::doh: my bad ppl!
Thanks all for the replies, I plan on picking up a Flex just to entertain my own curiousity. :xyxthumbs:
