MarkII backing plate not coming off
Where you ever able to remove the backing plate?
Yeah I was able to get the backing plate off the duetto. Used a ratchet with a socket that has the right size hex key size.
I go back and forth and to be honest it's not really that big of a deal. It I am using a washer(and mine are from KB I didn't make my own) I know I will most likely be cutting and using compounds. I will usually work at a speed 4 for foam pads and speed 3 for microfibers.
If I'm washerless then it's speeds 4/5 mostly. I love the polisher both ways. Another benefit of the washer is not worrying about lubricating the housing which really isn't a big deal either .
Try it without the washer first. All you need is speed 4. I've yet to go higher than that with or without the washer.
you ever hear the saying if it aint broke dont fix it it is a rupes why just use it i own a mark 2 15 i love it took out of box used it
I just got the mark 2 a month ago, ran it without washer mod, a little too sensitive on edges, I removed backing plate and put my washer mod in place, in my opinion it's 1000 times smoother and really shows the power. Also can hit my edges without the plate stopping completely. The backing plate is very tight, no loctite tho. Make sure u are turning the right direction. Good luck!
Sent from my SAMSUNG-SM-G900A using Tapatalk
I just said it use it both ways lol. I had the machine since it came out man. I know how to use it with both
How to remove it?
Mine took considerable effort to remove. Maybe you need to hit the gym! JK
I held the machine between my legs sitting down with the backing plate facing out. Then I turned the wrench towards me as hard as I could, came right off.
