WhiteShadow89
- Feb 5, 2019
- 66
Hello,
I had a bit of an unfortunate incident yesterday. While I was out running errands my wife and I accidentally left our lava soap jug on the washing machine. The lava soap fell off and must have landed perfectly on the pump handle as I came home to my Mustang completely sprayed on the driver side by it. After seeing this I begin prepping my soap buckets to get this stuff off my car asap. It thankfully appears that the ceramic protected my clear, however the plastic trim that was hit by the soap damaged the plastic trim. As you can tell from the photo below there are spots left over from the area that the soap sprayed onto (the very circular looking spots on the dark plastic trim) I tried every product I have (all purpose cleaner, glue/adhesive remover, trim restorer products) and it is there to stay. I am curious if anyone here has come across anything like this and has a recommendation? From what I can tell it may have ate the texture from the plastic. I know it is cheap plastic, but it was still wet to the touch when I started cleaning it.
If it helps, for those unfamiliar with lava soap it is a heavy duty soap that has a very gritty texture and is meant to be used to remove heavy grime from your hands.
Car: 2013 Mustang GT
Untitled by Sean C, on Flickr
