Mazda RX-7 SPIRIT-R
Nice job!
Is that a 3 rotary turbo motor? I know JPM made a 3 rotary 1.6L motor. I believe the reason the states never saw this motor was due to its poor emissions.
Ken
Nice job!
Ken
Not sure mate but i think it is a 3 rotor 1,3L turbo engine
Nice job!
Ken
Its definitely not a 3 rotor Cosmo engine. You can tell by the intake manifold. Also the 3 rotor engine was never in the states because the motor came from a Mazda/Eunos Cosmo which was only produced and sold in Japan for a limited time making it pretty rare.
This is a JDM car imported directly from Japan as a used one.....I don't know if the Spirit-R has the 3 rotor engine....
For the final production year Mazda have released a limited edition of the RX7, the Spirit R. The third-generation RX-7, first launched in 1991, has a particularly distinctive exterior design. Its lightweight, compact and high-output rotary engine enables the driver to feel superb driving pleasure. Epitomizing Mazda's spirit of sports car, RX-7 has won popularity among the customers since its 1978 launch. Mazda envisions the production of the current RX-7 model (FD-3S) to come to an end in August 2002.
The Spirit R series is available in three models: the Type A, a two-seater with a five-speed manual transmission; the Type-B, a four-seater with a five-speed manual transmission; and the Type-C, a four-seater with a four-speed automatic transmission. All three models are equipped with common interior and exterior features, such as BBS-manufactured 17-inch wheels, red brake calipers, and interior panels with a special soft coating, while each model shows off its own equipment to make a difference from the other.
The Type-A Spirit R is a two-seater model fitted with the Recaro-made exclusive red full bucket seats. These lightweight seats reduce the overall chassis weight of the vehicle by approximately 10 kg. Braking performance is enhanced through the use of large drilled type ventilated disk brakes for all four wheels and high rigid stainless mesh brake hoses. The Type-A Spirit R model is the ultimate RX-7, boasting the most outstanding driving performance in its history.
The Spirit R is available with five outer panel colors including Titanium Gray Metallic.
Company press release, last updated before 12 / 01 / 2004
General specifications
Country of origin Japan
Numbers built 1500
Produced in 2002
Engine
Configuration 13B R-EW R 2
Location Front, longitudinally mounted
Displacement 1.308 liter / 79.8 cu in
Fuel feed Fuel Injection
Aspiration Twin Turbos
Drivetrain
Chassis/body unitary steel
Suspension (fr/r) double wishbones, coil springs
Steering rack-and-pinion, power assisted
Brakes ventilated discs, all-round
Gearbox 5 speed Manual
Drive Rear wheel drive
Dimensions
Weight 1260 kilo / 2777.8 lbs
Length / Width / Height 4295 mm (169.1 in) / 1750 mm (68.9 in) / 1230 mm (48.4 in)
Wheelbase / Track (fr/r) 2425 mm (95.5 in) / 1460 mm (57.5 in) / 1460 mm (57.5 in)
Performance figures
Power 280 bhp / 209 KW @ 6500 rpm
Torque 314 Nm / 232 ft lbs @ 5000 rpm
BHP/Liter 214 bhp / liter
Power to weight 0.22 bhp / kg
