Hello All,
I will be picking up a new truck in a few weeks and have been thinking about what i want to do to protect the paint. The truck will be white, when i get it i will check to see if there are scratches or swirls (hopefully not, not expecting much). If the truck needs to be compounded/polished i would iron-x the vehicle, clay then polish. I have been reading and see that M105 and M205 have been a commonly recommended product (or would you recommend something else for a new vehicle) however i have read it is dusty and i live in South Louisiana where it is hot.
I have been reading a lot about the McKee 37 Paint Coating product. I am leaning towards that as well as their paint coating prep polish and the coating. I assume i would use this after i have used the above mentioned products?
After all of the polishing is it also a good idea to be double sure the paint is clean or any oil or anything else to do an IPA wipe?
Once i put the coating on and let is cure are there any other products recommended to put over the coating? Waxes, sealants or anything else?
Thanks for the input.
