Mckees 37 new formula paint coating
Cruzscarwash
I finally tried out the NEW coating formulation and all I have to say is ..what the hell did McKees do!!!
It's AWESOME!!!!
so as some of you know I pretty much only use mckees paint coating as my coating of choice due to the fact I work outside in the sun in high heats.
This new formula was not only easy to apply (not a big fan of the new applicator pad, so I used my old one) it was easy to see high or missed spots. It also covered up orange peel in my paint which you can see in the pictures I attached. My car needs to be repainted so not worried about the orange peel.
Most of you know I suffer from very hard water and waterspots are an everyday thing for me and I have yet to find any product that can prevent spots from forming if not removed after the first 24 hrs. No coating from cquartz to Dr Beasley or gyeon has helped in anyway.
I normally have to Chemically remove the spots and then Reapply what ever LSP it is I'm using and basically repeat each week or whenever I finally get to wash my own car.
The working time for this new formula was better and I tried to stretch it to do large panels but in my heat it still was not a good idea so I had to stick to very small sections of about 6x6 to 10x10 MAX.
As some have said the slickness of the original is gone and it does not have that same glassy feel but also does not have the rubber feel of other coatings. Overall I will continue to use this and am very happy with my initial impressions of the new coating, now to see how long it last and how well it protects.
Sent from my Pixel using Tapatalk
Can't beat it for the price.Even if it gets you 4 strong months of good durability that you can see than its a no brainer.
Idk if I'd go as far as that. I get that much protection from sealants with much less effort then mckees coating. I've gotten 9 months out of the original formula so hopefully this does better
Well lessons learned. I didn't flush the Pump after I did this review and when I went to go use it again it was clogged and crusted over.
I also forgot to wash my applicator so now that is ruined as there is a thing hard layer stuck to it.
Good to know. Thanks.
Contact Nick after the hurricane and maybe he can hook you up with a new applicator.
It's AWESOME!!!!
Looks like you forgot to clean your wheels.
The Salt Air ate them away so I kind of disregard them now.
Maybe someone can help me in this thread. I am currently applying coatings from Feynlab and was previously using CQuartz. How is it that these coatings are so much more "difficult" to use than the mckee's or wolfgang which appear to be more of a wipe op wipe off deal?
Hopefully Rich can shed some light on this because it has had me wondering for months now. Is it that the easy to apply coatings are "weaker" than the easy to use ones? "Less chemical resistance, lower duration, etc".
The first version didn't make it through winter for some and apparently didn't have any silica because the new formula claims it does.
The first version you could wipe off high spots very long after application. Guessing they didn't cure the same way ceramic or glass coatings did because they were not the same make up. Really all these LSPs are technically "coatings" cause you are coating paint with them. It's just jargon with no real definition of what has to be an ingredient
Find one you like try it and report back results.
I ordered the McKee's coating set last year around this time...
How do I know if i have the newer formula for the paint coating ?
Was going to apply it to my Dad's Durango next week
Thanks for the review. Can you elaborate on your method of cleaning the pump and the applicator pads? I have this issue. It seems to leak around the base after my initial use.
Also, did you use the McKee's Paint Coat prep? I'm not sure how to apply this paint coat prep after jeweling on very soft black Lexus paint. I used Menzerna 3800 to fine polish to rid of any marring and hazing. I if use foam applicator to prep using paint coat prep, it leaves scratches. I bought a kit (either from autogeek or mckees, forgot) and their foam applicator pad REALLY scratched up my soft paint finish. My method was to spray diluted ipa and very gently wipe off residue w/ meguiars mf and apply Mckee's old paint coat formula using LC foam applicator.
From the old formula, what I notice is it still stains pretty well from bee poop. but, it comes off like no other. What's your take on minor swirls/scratches and stains so far on this new formula?
The water behavior of the new formula 37 coating is awesome!
So NOW and with my cancoat I just take the pump off and place it in water and give it about 10 or so sprays
I didn't use the McKee's prep polish, I normally use essence or just a wipe down before I apply.
The pads I'm going to start washing right after the same why I wash my pads, blue Dawn, rub and rinse
Sent from my XT1609 using Tapatalk
