Mckees 37 tire coating? Multiple coats?
fightnews
I did all the prep work last night but I was only able to get 1 coat on. I always do at least 2-3. The car hasn't moved since last night. Is it Ok to apply a 2nd and 3rd coat over the first coat that's had 15 hours or so to fully dry? Should I hit it with some n914 first?
I just read the description of McKees tire coating. And if you want more gloss you can apply up to 4 layers but the longevity would not be different just the shine and gloss. If you want more gloss and it's clean as you have not driven it I would apply as many coats until I got the gloss I desired. Just wait 30min between layers. Don't think a wipe down with N-914 would hurt the first coat as it seems to Bond and cure fast. If you see any dust or something else on it. Is it clean I without looking to close to it I would apply it directly.
Please do an update on the longevity of this tire coating after a while. It's hard to find durable tire coating and dressings.
Lots of great tire coatings out there!
do at least 2-3.
some n914 first?
IMO:
•If the Coated tires got dirty enough—while
sitting in the same spot, overnight—to where
they need to be washed down with some
N-914 before further applications of this tire
Coating can be administered...
-then I imagine that the rest of the car
must have accumulated a similar amount
of uncleanliness: Time to get cracking!
I've been using McKee's Tire Coating for over 2 years now and frequently get 3 months or more longevity before needing to scrub the tires down with McKee's 37 Tire & Rubber Rejuvenator and re-apply (2) coats. The key to using this coating is that the tires must be absolutely free of previous tire dressings before applying the initial application.
IMO:
Not to far off lol
I've also been using it for a while. The first coat is already on and cured. Now I need to tweak my original question. Can I do a 2nd coat next weekend after washing with soap and water
Absolutely...go for it!
How about if I do the second coat tomorrow after work. The car will have been driven by then maybe I could just do the wipe down and recoat?
So I used the recommended application brush. This time I also used a detailing brush with the wood handle to help spread it out. It came out great. Better then all the other times Ive used it.
Get yourself a metro vac side kick. Will cut your drying/curing time down by a lot. Then you can add multiple coats within a short period of time.
To answer your question give it a good wipe down prior to adding another coat if you are driving it.
down and recoat?
spread it out.
•If that is the case; then, IMO:
-I really don’t see why the tires need
more than the one coat. Why not just
go ahead and enjoy your handiwork?
-The time to “renew” the Coating
will come soon enough.
This is true but I think the 2nd coat will add to it. I just think applying with the detailing brush made a big difference. It got me in all the tight spots and crevices
The last time I scrubbed down the tires with Tire & Rubber Rejuvenator was the end of October. I applied a single coat after cleaning with soap and water and allowing the tires to dry. They still look great.
