Maybe Mike has some sweet chart stored away somewhere and would like to share. I sprayed some full strength on some bug guts and they just melted away. Was just wondering whats too strong for some applications and what is just wasting product.
10:1 and 4:1 are the dilution levels...
Here's something on APC+
All Purpose Cleaner Plus
Meguiar’s® All Purpose Cleaner Plus is a true all surface cleaner ideally suited for today’s fast paced, high volume, detail operations where one simple solution is needed for a wide variety of cleaning needs. It provides mixtures for heavy cleaning of engines and tires, fast interior cleaning, as well as a low foaming ratio for use in carpet and upholstery extraction machines. Leaves carpet clean, smelling pleasant, and the fibers soft with no sticky residue. Safe for clear plastic, glass and leather.
(Low foaming is important if you're using an extractor)
Dilution: Water: Degreaser
Heavy-Duty Strength: 4:1
Medium-Duty, interiors: 10:1
General cleaning, cold water extractors: 20:1
General cleaning, hot water extractors: 64:1
I mix my APC/APC+/Wheel Brightner/Super Degreaser to 7:1, easy forumula, 28oz of water and 4oz of product and gives you 32 oz of product.....
Here is the bottle and how to mix.....
Here is a chart for mixing ratios, I picked 7:1 as it's ease of mixing.....
So far the 7:1 ratio has worked well for me, not too strong and not too weak.....I have a back up bottle ready to go when one runs out.
I fill my bottle to the "fill" ring above the label with water and top with product to just about the first ring on the neck or so. Works well and quick for my 7:1 ratio.
APC? APC = All Purpose Cleaner and I use it on just about everything to clean, engine bays, interior, tires, door jambs, household stuff etc....
APC+ is a low foaming forumula for carpet extractors and works great.
What's the dilution ratio for APC to be spray and wipe?
Do you mean for use to de-wax paint? That is to strip wax?
Hey Mike.
I'm meaning, if I was to use it in things like on the door hinges where old oil and grease build up. As in, I can spray it on, then wipe the crud and oil that builds up off, but, without having to rinse it out (for stuff that Quick Detailer won't touch due to it's oily/ greasy nature).
Is there any dilution that it's ok to do this at, or will it always leave behind surfactants? (which promote re-soiling)
Thanks,
Matt.
